FMS multi wing connectors
  • Pheonix
    • Aug 2013
    • 670
    Can any one give me some instructions on how to use these? I would appreciate the help.
  • ryramZ
    Pilot Ryan
    • Dec 2012
    • 814
    Re: FMS multi wing connectors
    Hi Phoenix, did these come with a plane or did you buy them separately? Just curious what you are using them in. Ill take a look at our Dallas Darling this evening and get back to you.
    Ryan
    • ryramZ
      Pilot Ryan
      • Dec 2012
      • 814
      Pheonix, these are the instructions from the FMS Dallas Darling that uses these connectors. It really is very slick. I hope you can read the print. Let me know if you have any more questions.
      Ryan
      • Marco Polo
        Go NAVY
        • Aug 2012
        • 609
        • Illinois
        Guys, I made a quick .pdf so it's a little easier to read. It's on the multi connector product page under the Support Tab and also here is the link: Click Here
        • Pheonix
          • Aug 2013
          • 670
          Thanks Ryan. I appreciate you responding to my request for help. I am using on other FMS planes. These should make removing the wing for transport much easier.
          • Pheonix
            • Aug 2013
            • 670
            Thanks Mark. MRC is the best in every aspect.
            • Pheonix
              • Aug 2013
              • 670
              thanks for the PDF. I got them to work on my F4U. Now I can remove the wing for travel to the field. Again, many thanks.
              • ryramZ
                Pilot Ryan
                • Dec 2012
                • 814
                You are very welcome! Thank you. Now the instructions are up on the website linked to the items. Your question will help many people.
                • Chris_UAE
                  • 19
                  Hi Ryan,
                  thanks for the post and for sharing the PDF on FMS main wing multi connectors. I am planning to install the sam on my FMS T28 Torjan, 1400mm. I hope the installation will be easy, as I would like to do away with the number of wires that need to be connected in that plane. Any advice or reference would be highly appreciated.
                  Cheers
                  Chris
