electric motor orientation
  • ImpulseIII
    • Mar 2019
    • 6
    Sorry for this very basic question buy, I bought a Flex innovation 300 extra with out motor. I have a motor from another Flex 300 Extra but cannot fine any documentation on its installation relative to thrust. I have several planes that are angles slightly to the right but have no idea on orientation relative to up or down. Are there any guidelines or is there a video that may provide some insight?
    Thanks in advance....Frank
    • 8831
    Doesn't the new plane have a firewall/motor mount plate? It should be at the appropriate angle for the motor. If not I've built planes that have no motor firewall and the plans say 2 to 3 degrees down.
    • ImpulseIII
      • Mar 2019
      • 6
      Thanks, what about left/right orientation. The fire wall is flat but one of the flanges on the motor mount is bent inward a few degrees. I am sure the is to provide the proper angle, my problem is I am not sure where the "bent" flange should go relative to the fire wall. (what corner).
        • 8831
        Looking at a couple of my single engine prop planes (tractor), they are down and to the right.
        • ImpulseIII
          • Mar 2019
          • 6
          OK Thanks
