How long does a plane last you?
  • Dillon Hoffmann
    • Feb 2022
    I have been really interested in the world of RC aviation for the past few months, and have seen the most beautiful models. My question is, how long do people usually fly their planes before they retire them. I know crashing is a part of the hobby, but is it possible to get a few years out of a plane before destroying it?
    My question refers to both balsa and foamies.
    • 8835
    If you are asking about a plane's natural longevity, then you have to eliminate "crashing" as this injects a parameter that can't be always controlled. If you include crashing, then I've seen guys (myself included) whose planes last 10 seconds - straight from the start of the take off roll and right into the garbage bin - OK, a few minutes then. Sometimes it take a while to gather all the pieces up.
    If you eliminate crashing, then you need to define at what point does a person get tired of a plane and at what point a plane wears itself out. The first point depends on the person and the plane. Of the 50 or so planes I current still fly, several of them go back 7 or 8 years and still fly well. Then there are planes that have components that are DOA, while others may take a couple of seasons before something on it dies and needs to be replaced. I have yet to see a plane naturally wear itself out. Your question doesn't have a simple answer for most.
    • Gilatrout
      RC Pilot Addict
      • 806
      • Albuquerque NM
      Every plane has an expiration date.
      I have foamies and balsa planes that are many many years old that I still fly. Some have a lot of hanger rash, some have less.
      Protecting the plane with things like wing bags or careful storage can keep a model airworthy as long as you can still power it
        I still have a park zone p51 that flys as great as the day I bought it
        • ZeeFlyGuy
          • Apr 2022
          • 14
          • Houston, Texas
          I have an FMS F6F 1400mm Hellcat I still fly that was built about 10 years ago made of EPO foam, but I also have a F22 made from EPP foam that I built 3 years ago that the foam is getting a bit dry but still flies well. A good quality plane can last a long time if cared for ie storing it in a garage here in the South Texas heat will have an effect on it. I have a dedicated spare bedroom for plane storage, Balsa and monokote may need a bit more care as the monokote can deteriorate if exposed to heat or sunlight for long periods.
          • jasmith41
            EDF-obsessed
            • Sep 2021
            • 317
            • AZ and NE Ohio
            all of mine have lasted a year, aside from the ones i've crashed and replaced - but then again, i only started flying a year ago...🤣🤣🤣
            • kallend
              • 1877
              My Delta707 just passed its 50th anniversary (built it in 1972). Converted to electric 6 years ago, and still fly it regularly. The plans were published in 1957.
              https://freercplans.com/plan-delta-707-1308.htm
              • Dirty Dee
                • 768
                • Northern Illinois
                My Durafly P-51 lived from 2011-2017, with 4 moderate crashes that involved repairs. Retired to make room and to put the battered airframe out of it's misery.
                My Durafly T-28 I have owned since 2018 with 121 flights, still going strong without a crash.
                Freewing Yak-130 70mm since 2017, 156 flights with its first crash last year due to high alpha shenanigans at too low altitude. I did notice during repair that the glue was starting to let loose and get brittle, and actually minimized the damage to the airframe since it popped open at the fuselage glue joint.
                Freewing 80mm A-10 since 2017, 68 flights, minor belly damage from a bucking bronco aborted landing in 2019 that sheared the nose pin and required a belly landing in grass.
                I also had the 70mm Freewing F-16 and put 71 flights onto it before selling it. no crashes, but wanted to make room for a larger plane.
                  • 5426
                  I have planes from the 70’s. Foam EDFs almost 20 years old… hundreds and hundreds of flights on it.
                  • wvrailfan
                    • Sep 2013
                    • 682
                    • West Virginia
                    My Dynam WACO is the old timer in my fleet. I got it in 2012, lost count of flights somewhere after 300. I still take it to the filed and it still flies great.
                    I have a couple of others that are ten years old, but I started flying in 2011.
                    JB
                      • 7437
                      Ten years old and still flies like a lady. Upgraded the motor/ ESC and changed the tires, hey they wore out!
ID:	402298 Click image for larger version
                      • kallend
                        • 1877
                        Still flying this one; it is 52 years old this year. It's a "Delta 707" from Aeromodeller Plans Service, Jan 1957 issue. I made it in 1972
                        Click image for larger version  Name:	img.jpg Views:	0 Size:	175.0 KB ID:	402383 Click image for larger version  Name:	Delta707.jpg Views:	0 Size:	297.1 KB ID:	402384 Click image for larger version  Name:	6.jpg Views:	0 Size:	22.3 KB ID:	402385 Click image for larger version  Name:	4.jpg Views:	0 Size:	73.2 KB ID:	402386
                        • NewbieBob
                          Back at it
                          • Sep 2022
                          • 83
                          • Eastern Ontario
                          Very Kool Kallend. I'm glad to see you kept it original.
                          it is a proud piece of our history.
