Hi everybody,
i have freewing su-35 for almost 2 years. about 2 months ago i upgraded fan units to Extrême Alloy CS12 Blade combos with Typhoon 2w30 inrunner motors. Also upgraded ESC to Hobbywing 100A ones. using Pulse 5000 mah 65c battery. After that i had about 50 flights and crashed twice because leads from esc to battery becoming so hot that melted sattering material and wire come loose. after first crash i rewelded all connections to make sure there is no cold sattering. but this mourning it happened again and i dove from 150 ft straight down to runnaway.
where can be the problem? in both crash flights i was not pushing it to the limits ( wasn't try to hoover or smth.).
thanks a lot i advance.
