Data Logger
  • Data Logger
    I've been looking into getting a Data Logger and was wondering if anyone has used one and has any thoughts about them . I have looked at a couple different ones which one for the price is best ?
    Bryan
    But Crashing is Landing
    Bryan
    hobby king sells one. I believe version 2 is around $50. I recently borrowed one from a buddy and put it in my freewing rebel 70. Top speed was 89.5mph on a downwind pass. I was happy.
      here's the link..http://www.hobbyking.com/hobbyking/s...arehouse_.html
        Thanks a lot CZ , bad part is its only available from the EU warehouse . By the time you get it here it will be close to $100 .Been looking at the one MRC has . Hope to find out more about it .
        Bryan
          Bryan
          Check back on the site once in a while. Sometimes they show up in the U.S. warehouses. Plus,if you would, post a report on what you end up getting. Thanks! Ron
            Not sure what you want to log, but I use the FrSky sensors in just about every plane I fly. You can see real time data on the TX (useful for before takeoff) and program it to show max and min values after the flight. It also logs data on an SD card in CSV format. You can usually outfit a bird with airspeed, rpm, two temps, and lipo sensors for around $60-$70. They have some real nice altitude sensors as well. But that sensor needs to be located in an enclosure with a static port. Otherwise colling air flowing through the bird will show as an altitude change.
            Nice thing about that radio is that I can use sensor data as logical switches to give warnings, start logging, etc. For example I start logging when RPM is above zero. That way I can work on my bird and not log useless data. I also start a total-time-on-aircraft timer anytime rpm is above zero.
