air titan motor beeping?
  • stitch
    • Dec 2014
    • 142
    ya i got mine together and tried out everything worked goodwell unplugged battery was setting up flap throws plugged battery back in all it does is beep from motor,checked receiver it is bound oh elevator and rudder works motor won,t arm any idea,s how to fix i,m thinking esc lost binding somehow never did anything but what i said anybody have this happen before?
  • stitch
    • Dec 2014
    • 142
    that is strange i typed this first one in then went feed dogs came back changed the throw for throttle to reverse it worked. so i changed it back to were it should be at and still works so i,m alittle worried now about flying if it may start acting up in flight.
      Stitch,
      Just reset your throttle range and you should be good to go.
      • WintrSol
        • Nov 2013
        • 499
        • Florissant, MO
        The transmitter must be on with the throttle at minimum for the ESC to arm, of course, the ESC must first be trained to the throttle range.
          • 8755
          Constant beeping from motor could mean throttle is too high (put throttle to min and throttle trim tab to the bottom) or one of the ESC connectors is loose or wire insulation broken. Also check throttle plug in Rx is solid.
          • stitch
            • Dec 2014
            • 142
            did all the things everyone said to check,did that before i did post.seems to be working now but who knows when it will act up again,will keep an eye on it.thanks!
            • WintrSol
              • Nov 2013
              • 499
              • Florissant, MO
              If it comes and goes, I would start here. I've had the spring part inside the contacts collapse, sometimes even fall out, making for a random connection. A bright light and magnifier, or just a single pin to test friction, one contact at a time will find this.
              • stitch
                • Dec 2014
                • 142
                wi;; check that out did not do that.i wiggled all the wires around while it was running no cut outs,runs good.
