Mode 2
  • MEDIC1972
    • 24
    • Napa, California
    Mode 2
    As my son and I venture into building our first airplane together, I have been researching radios and engines, I have found the ones I want... but, it's been so long since I last flew, Mode 2 is the throttle on the right correct?
    • 2816
    • Arlington, TX
    No, mode 2 is the normal (for North America) layout, throttle on the left, ail/elev on the right: http://www.spektrumrc.com/Articles/A...ArticleID=2105. Good luck on the project, I'm sure the project will be a great experience for both of you to share!
    • Beeg
      • 1335
      • Texas
      Yeah, we have two guys at our club that fly Mode 1 and the British guy not only flys Mode 1 but has his throttle setup like the French did in WWII with full throttle being back not forward.
      • MEDIC1972
        • 24
        • Napa, California
        Thank you for the input, I learned on Mode 1 and I remember the reason why (typical general aviation aircraft, Cessna, Piper, etc) the throttle is to the pilot's right. The radio I plan on purchasing is a Futuba (I know that they are reputable, they have around since I started flying back when I was 12... so 32 years) but it comes in Mode 2, can they still be easily converted to Mode 1?
        • WintrSol
          • Nov 2013
          • 499
          • Florissant, MO
          Check out http://www.futabarc.com/faq/ - they answer that question for the 7C, so select your model and see if it is there, too. You may have to modify the sticks, to change the spring-centered RH stick to normal throttle control.
          • MEDIC1972
            • 24
            • Napa, California
            Perfect! Thank you, it can be done with the model I want.
            • WintrSol
              • Nov 2013
              • 499
              • Florissant, MO
              Note that they recommend sending it to a service center to make the mechanical changes; it is a tricky mod.
              • MEDIC1972
                • 24
                • Napa, California
                I will most likely send it out, don't want to drop the money to mess it up... however, the State of California lets me work on people lol
                • MEDIC1972
                  • 24
                  • Napa, California
                  Again, thank you all for your help and feedback
                  • PappaBear
                    • May 2015
                    • 377
                    • California
                    All most all current radio systems can be changed to any of the 4 modes, 1,2,3,and 4. The most populars is mode 1 and 2. All current Futaba and Spektrum systems can be changed quite easily. You do have to move a spring across from one side to the other in a Futaba TX. A Spektrum only requires that you adjust a couple of screws. However you will have to perform a system change in the program, but both are simple to do.
                    The Detrum radio that Motion RC carries can also be changed from mode 1 to 2 and vise versa, however with this system you have to physically change over the stick assemblies from left to right and again you will have to perform a system change in the program. The stick change sounds more difficult than it actually is . But you will require the special screw driver bit to remove the screws holding the still assembly to the case.
                    I hope this helps anyone who would like to carry out the change.
                    Martin.
