I had the "mysterious fall out of the sky for no apparent reason" issue. I was transitioning back to MR mode and it just nosed in from a few feet up. Aside from a broken servo arm and a slightly crinkled nose, there was no other damage. Wasn't a battery issue; had plenty left in the pack. Unfortunately, E-Flite decided to use servos that had a really odd spline count (20T) and even though I have what seems like 1,000 spare servo arms, none of them fit (of course). I found two Solar A107 MG servos that were a drop-in fit but the E-Flite servos must either be digital, or be of a specific pulse width or something because the Solar servos really acted strange. They even did what was opposite of what was commanded on the transmitter. So I called HH and they kindly sent me two replacement servo arms. I have yet to install them (the crash occured on NYD); other projects took priority such as my Super Scorpion and F/A-18E V2.
But I have to agree, when it flies, it flies great. But the sloppy programming in the flight controller (the oscillation when transitioning from MR to AP, the way it's so sensitive with no way to adjust it, the creep forward/no backwards in MR Stability Mode, the weird way it will sometimes just cock backwards at a 40-degree angle in MR for no reason, the hold-onto-your-butt instability of when it descends in MR/Acro mode) just really takes away from what should be a really cool product.
I've heard that the next batch of Convergences have been delayed 2-3 months? Wonder if they stopped production and made some adjustments? If that's the case, I sure hope they take care of early adopters/beta testers. I'm not asking for a new plane, but perhaps a new FC (in exchange for my old one) or even a software flash of my old one would be wonderful.... assuming they are making changes to the production line and assuming the FC is part of those adjustments of course.
