What's next from Motion RC?
  • fhhuber
    • Aug 2015
    • 1476
    Originally posted by dahawk
    I would like a F4J that gets more than 3 minutes Flying time. Need the next jump in batts. What an engineering opportunity for somebody.
    You can fly longer now.... just go slower :p
      • 2818
      • Arlington, TX
      Exactly. I can get 5 min + on my A-10 with some throttle management, and about 4 min on the F-4 and F-86. I don’t consider that too bad considering my prop planes generally get 5-6 min.
      • fhhuber
        • Aug 2015
        • 1476
        Generally a 70 mm EDF needs 150% of the watts to get the same performance as a conventional 2 blade prop (just put it in the nose and stick on a spinner)
        That means you have the heavier EDF installation with a bigger heavier motor and you need 150% the battery weight to get the same flight time... and then with all that added weigh, you might not get off the ground.
        So we sacrifice on battery capacity. (and still end up heavier and slower than we would get with a conventional prop at the same watts)
        But the appearance and sound make up for it. and the type models we put EDFs in tend to be fast by design.
        There's some economy of scale letting bigger EDFs be a bit less inefficient compared to the conventional prop also.
        • Cws
          still flyin
          • 112
          • Ft worth texas
          I sure would like to see an 80 mm Panther and a B-26 Invader in the silver Korea paint same size as the tiger cat.
            • 2818
            • Arlington, TX
            Maybe my numbers are a bit biased then. I only run 2 blades on my Cub. Everything else runs scale diameter (or close) 3-5 blade props. For those, flight time heavily depends on flying style as well. Hammering full throttle on my FMS P-47 probably would be a 3-4 minute flight. Flying it scale with mixed throttle and a few high speed passes had given me flight times up to 10 minutes.
            • Oxotnik
              Actung, Spitfire!
              • 931
              • Huntsville, AL
              Warbirder
                Originally posted by Oxotnik
                Click image for larger version  Name:	DF133D2D-5D6E-4F7D-A4CB-FE296FCC115E.jpeg Views:	1 Size:	106.6 KB ID:	132011
                YES
                • gooniac33
                  The Original Gooniac
                  • Jun 2016
                  • 1047
                  This is why I hate edfs
                  You would hate me then!! I get almost 10 mins flight time with my FMS Hawk.... LOL LOL LOL on a 6s 30c 4000mah pack no less!! And then with my 70mm F/A-18 I can get up to 6 mins with that one... and with my 70mm Avanti I am getting the same 6 min flight times and using the same pack... Its all in the way you fly and the way that the system is set up. Now with warbirds my FMS 1450mm warbird is amazing!! almost 15 mins flight time on my 4s 30c 6200mah pack and when I go to 5s 30c 4500 I still get 10 mins but with better climb and speed! Lots can be done when you move the throttle stick more than just on and off...
                  • dahawk
                    Augermeister
                    • Jun 2013
                    • 1006
                    • Keller,Texas
                    I admit I put the pedal to the metal. lol
                    • gooniac33
                      • Jun 2016
                      • 1047
                      yeah its fun to do that too! But I am loving touch n goes as well as laid back formation flying.
                        • 2818
                        • Arlington, TX
                        I've never seen an edf that would fly well below half throttle, they would just fall like rocks. Since then I lost all interest in those things
                        You have never seen the twin 80 A-10. Happily flies at 1/3 throttle :Cool:.
                          • 2818
                          • Arlington, TX
                          That's pretty much why that is the only one I'm considering to try since the last I've flown one was in 2009
                          Dude, those weren't even in the same universe as these newer models!! Power, handling qualities, landing gear, and surface finish have exponentially improved since then.
                          • dahawk
                            Augermeister
                            • Jun 2013
                            • 1006
                            • Keller,Texas
                            With twin 6S 6250mah 35 RT's I can get 5 min with the A-10 which of all of my edf's offers the longest flight times. DD is 100% correct about the A-10's wide speed range. With throttle management( hard for me to do) I get about 4 min on the BAE Hawk T1 with an Admiral 5000. The A-4 is around 3 min.maybe 3.5 min on a good day. But that's just me.
                            • Oxotnik
                              Actung, Spitfire!
                              • 931
                              • Huntsville, AL
                              Rifleman, you should try a Freewing 80mm F-86. It's a fantastic EDF and has a great glide slope and flies very well at low speed. A buddy of mine just got a Flex Innovation Flexjet and it's crazy the things that he can do with it and how much flight time he's getting.
                              Warbirder
                                I am seriously considering picking up one of those Flexjets...They look like a ton of fun with a crazy gigantic flight envelope.
                                • DR. Joy
                                  • Oct 2017
                                  • 32
                                  I think the next plane is the MiG15. Here is why. It was the foil to the F-86 Sabre. It is the product of a failed empire: the USSR. They were in a natural metal finish like Aluminum foil is (in Korea). The only way I can think the Summer Breeze thing figures into it is that the First MiG flown by Western pilots had faulty climate control and the A/C did not work.
                                  That is my best guess.
                                  • DR. Joy
                                    • Oct 2017
                                    • 32
                                    Then I must ask where the cloud atlas fit into your equation? That was his last clue on foil.
                                    That is where the whole "Best Guess" part comes into play.
                                    • DR. Joy
                                      • Oct 2017
                                      • 32
                                      Indeed. A large mig 15 would complement the f86 for sure though.
                                      Also it spawned the Mig 17 and MiG 19. That is where I think "Cloud Atlas" comes into it.
                                      Of course: I am likely to be completely off base.
                                      • dahawk
                                        Augermeister
                                        • Jun 2013
                                        • 1006
                                        • Keller,Texas
                                        I was leaning towards Super Sabre. A Sabre being a foil.
                                          • 7437
                                          https://en.wikipedia.org/wiki/Cloud_Atlas_(novel)
                                          Might be something here......
