What's next from Motion RC?
  • Bearcat
    Hobby Squawk bomber Pilot
    • Oct 2017
    • 176
    • Cincinnati area
    Ok, so put the foil hats on and look at Alphas breadcrumbs
    1. Foil = EDF
    2. Hoot = Fast, Foil = Faster
    3. History:
      1. Military Campaigns, Projects,
      2. Alphas prior hints / clue’s, pattern
    4. Cloud Atlas:
      1. Story: consists of six nested stories, whereof each is read (or observed) by a main character of the next. The first five stories are each interrupted at a pivotal moment. After the sixth story, the other five stories are closed, in reverse chronological order, and each ends with the main character reading or observing the chronologically previous work in the chain. Each story contains a document, movie, or tradition that appears in a previous story.
    5. Ozymandias:
      1. A poem that describes a broken statue of a legendary king of ancient times, lying forgotten in the desert, with these words carved on its base: “My name is Ozymandias, king of kings: Look on my works, ye Mighty, and despair!”
      2. An ancient Greek name for Ramses II of Egypt
      3. The poem Ozymandias is ironic as it mocks the “King of Kings”. What was once great is now in shambles. (Man’s Hubris)
    6. Foil:
      1. To prevent (something considered wrong or undesirable) from succeeding. (Maybe..)
      2. The track or scent of a hunted animal. (Na….)
      3. A light fencing sword without cutting edges but with a button on its point. (Na….)
      4. In fiction, a foil is a character who contrasts with another character— to highlight particular qualities of the other character. In some cases, a subplot can be used as a foil to the main plot. (Maybe…)
      5. Math’s “foil” method? (Na…)
    So, Historic, Fast, spawned many generations, great plane but now lies in the desert and was used to stop other other planes. And that plane is?????
    Why do I feel like Alpha is Geppetto yanking on strings......
    ANSWER- F-102 Dagger.
    Just let me fly so I may be free
    • wolpertinger
      Pilot ??
      • 313
      • Earth
      interesting as it is part of the Century series....and we have already had some released.....
      The Century Series is a popular name for a group of US fighter aircraft representing models designated between F-100 and F-106 which went into full production. They included the first successful supersonic aircraft designs in the United States Air Force's service, which remained in active service well into the 1970s and 1980s with the Air Force Reserve and Air National Guard.
      Clockwise from bottom: F-104 Starfighter, F-100 Super Sabre, F-102 Delta Dagger, F-101 Voodoo, and F-105 Thunderchief
      • GPJ
        • 31
        Convair FTW .... would love to see a hybrid jet / prop like XF-81
        • Dennispsg
          • 4
          1. Foil = EDF
          3. History:
          4. Cloud Atlas:
          5. Ozymandias:
          6. Foil:
          Interesting summary thank you, if you look up aviation history foil ( http://aerospacelegacyfoundation.com...-flying-wings/ ) lo and behold we have a wing less aircraft, but even more interesting is the guy who developed it no less than a Mr. Horton. This foil would not be a EDF but a German Mr. Horton developed a successful flying wing, as we have the other small German model is this going to be another small twin EDF flying wing I wonder.?
          • Bearcat
            • Oct 2017
            • 176
            • Cincinnati area
            I like your thinking but I believe Alexander Lippisch and his work on the Delta wing aircraft would be closer on mark, since Delta wing aircraft started a long line of jets from the F4D Skyray, F-102,F106, B-58 and a ton of European aircraft should tell you something there. Would I love to see a Horten HO-229 - YES YES..but from what I understand it might be difficult to do, even since we have seen countless models that were made and flew very well!!!! Lippisch worked with Douglas on the Skyray.. :-) (Would love to see a F4D Skyray!)
            • EA-6B Geek
              EW Misfit
              • 485
              • South Central Ohio
              Click image for larger version  Name:	image.jpg Views:	1 Size:	273.4 KB ID:	129014[/LIST][/LIST]So, Historic, Fast, spawned many generations, great plane but now lies in the desert and was used to stop other other planes. And that plane is?????
              [/QUOTE]
              Great analysis! F-100, forlorn in the desert. The F-107 the final story, looking back at the rest of the Century Series. Makes about as much sense as anything else I've read so far. Of course, it will be something we are 180 degrees from......
              • Bearcat
                • Oct 2017
                • 176
                • Cincinnati area
                Great analysis! F-100, forlorn in the desert. The F-107 the final story, looking back at the rest of the Century Series. Makes about as much sense as anything else I've read so far. Of course, it will be something we are 180 degrees from......[/QUOTE]
                China Lake is where you can find the F-4D Skyray - is that far enough in the desert for you?
                • Porkster
                  • 290
                  • Suffolk, UK
                  If its not an F100 I don't want it!!!:P
                  • Beeg
                    • 1335
                    • Texas
                    I’m thinking it’s a 90mm He-162...
                    • tclaridge
                      Instructor Pilot
                      • 141
                      That would be cool. I would have to have one of those!
                      • Bearcat
                        • Oct 2017
                        • 176
                        • Cincinnati area
                        I already own one- it's 5 feet long with a 4 foot wingspan.. 90mm fan... :-)
                        • Bearcat
                          • Oct 2017
                          • 176
                          • Cincinnati area
                          Now that would be interesting since there is one in Chino California.
                          • EA-6B Geek
                            EW Misfit
                            • 485
                            [QUOTE=Bearcat;
                            China Lake is where you can find the F-4D Skyray - is that far enough in the desert for you?[/QUOTE]
                            Hey Bearcat, I'd be all over the Skyray thing. I have a personal bias for Naval Aviation, and for the Douglas Aircraft Company. A BIG F3D would be cool too.
                            • wolpertinger
                              Pilot ??
                              • 313
                              • Earth
                              Just a thought on the F100, the air inlet may not be enough FSA for the Edf which means cheater grates...:(
                              Hey Bearcat, bring that F100 to Edf Jet Jam, love to see it..and as always....Goooooo Navy....... :)
                              • tclaridge
                                Instructor Pilot
                                • 141
                                Alpha, can you give us an approximate time release? It is fun to know about when a new release is coming out, then you can continue to tease us on what it is. I need to know how long I have to save my lunch money!
                                  Summer breeze, makes me feel fine...
                                  • tclaridge
                                    Instructor Pilot
                                    • 141
                                    That's wonderful to hear! BTW, anticipation is half the fun. Speed is the other half, and quality and detail is the final half.
                                    • lmramos44
                                      Jet Pilot
                                      • Mar 2014
                                      • 199
                                      • San Leandro, Ca.
                                      THIS IS WHAT I'M AFTER!!!!!!!!!!!!
                                      Me Too...
                                        What are you talking about? I'm simply singing along to an old 70's classic. LOL ;)
