super slow and lightweight plane
  • 0561joni
    Hi everyone
    I'm looking for some tips on how to build a very slow and light aircraft.
    basic dimensions:
    span less than 600mm
    weight less than 40g
    speed as slow as possible with good turning radius
    Components:
    I have 1 small engine and 2 servos
    The plane I want to upgrade has a basic rib-profile (ribs out of balsa with condesator foil) and about 30 degrees of dihedral. For maneuvering there is only rudder, elevator and engine. The fuselage is one carbon stick.
    Here a video of the plane: video
    How would you improve the speed (slower) and reduce the turning radius - is a biplane interesting?, dihedral too big?, v-tail more efficient?
    thanks for your help
    74 Likes, 1 Comments - AirRace TU Berlin (@project_airrace) on Instagram: “Staging constrains of the challenge #indoor #flying #ultralight #airplane #improvingeveryday…”
    • 8795
    I don't know what kind of motor you have or what type of servos, but scratch building something that light will be a challenge. If you enjoy that sort of thing, great! I doubt you can build one any lighter (or easier and cheaper) than just buying something like this out of the box:
    The Night Vapor BNF, 376mm by ParkZone is a quality built remote controlled airplane. See all our RC product options online at Horizon Hobby!
    I had one and flying indoors, it was so light that even ceiling fans 3 stories above (large atrium) would affect its flight. In a room like in your picture, it should do fine.
    "Interesting" is in the eye of the beholder. Dihedral is for stability in a straight line and the ability to level itself after a turn and reduces the need for ailerons. V-tail is only "more efficient" in terms of making the plane go faster. You see V-tails mostly on fast planes. The conventional horizontal stabilizer and vertical rudder is more efficient for slow speed as it needs less airflow to work.
