Acquired this hand built airplane from a gentleman who unfortunately no longer could fly.
The engine is literally mint condition. It has insane amount of torque, barely on the throttle and would just pick up ground in the runway.
Has nice built in flaps, all servos work. The outer surface of the aircraft needs to be smoothed out as it has cosmetic peeling, not structural damage.
Will give it a shot at this large scale, and see how it goes. Did a range check, let it ran half a tank, no leaks, no loose bolts or falling parts, servo settings set.
** Do have the cowl, took it off to view everything was sound and tight for flight.
