I have a Hangar9 P-51D "Miss America" that I have just about finished assembling. This is the 60 size P-51 with 65.5" wing span.
I also have a Great Planes (GPMQ4160) Fuel Filler Valve that I want to mount in the plane.
The firewall is solid, with only the neck of the fuel tank protruding, and the cowl is made of fiberglass, so mounting the fuel valve on the cowl doesn't seem to be an option.
If I mount the fuel valve on the fuselage itself, I would have to drill two holes in the firewall and loop two fuel lines back into the fuselage to connect to the fuel valve. That seems rather sloppy, though.
I have considered making a strong metal L-bracket and mounting the bracket on the firewall such that the other leg of the "L" would be right against the cowl. Then a hole through the cowl and bracket would be a place to mount the valve.
I'm certainly open to suggestions or methods used by others for this sort of thing.
Thanks,
Jack
Thanks,
Jack
