FMS Fox
    Just hovered my Mini-Connie again and the wife demanded I get her noise cancelling headphones. Whimp!
  • Felixs10
    Agreed ! I’ve been playing a lot with the Nintendo switch and terrorizing my wife with a micro FPV quad in our bedroom from the basement 2 floors below .. drives her nuts and she can’t wait to get me out of the house in spring LOL
    It's -17F outside at the moment. We won't have flying weather till April if we're lucky. My Fox will remain in its box for a while yet, along with the new Corsair and V-22 Osprey. The YF-23 is not quite 1/2 done on the table. I was able to hover the little Mini-Convergence in my living room a few days ago. And yet, I have a feeling another 2 to 3 months won't be enough to get them all ready. Kinda in the winter laziness mode.
  • Felixs10
    Yeah, that's a bit taxing. I fast forward it and you can see the points where he talks about CG because he has those CG marker stickers. That's when you can back it up and listen to what he says. If memory serves, he's about 10mm (maybe a bit more) aft of where the recommended CG is stated. The great thing about this plane is that due to its size, it will fly OK at several balance points. It's up to the owner to determine where exactly to suit his needs. Do you want to maximize the glide or do you want more wind penetration or do you want to do mostly powered, aerobatics? And to do those things, you may want to play with the size of battery that you use. RCInformer started with the stock CG and messed around with it and changed battery sizes along the way and he seems to have optimized the flight of his Fox for each type of flying.
    I watched it today .. it was informative.. I’m going to start at about 5mm rear of the stated C/G . I’m ready to go minus the weather !!! LOL .. I have this , the F22, am rc lander f4f panther, and a gas powered extra to madien once the weather breaks ....
    thank you for your input as well ....
    Originally posted by Felixs10 View Post
    I started to watch that video , but it’s like 45 mins long ...
  • Felixs10
    The videos done by RCInformer has shown various CGs and what his impressions are of each. According to his experiments, the best CG is NOT the stock one.
    FMS is notorious for publishing the wrong c/G , what’s everyone flying at ?
  • Felixs10
  • t33jetman
    Originally posted by Spookyeng View Post
    Thanks, I appreciate it! I am humbled by the work you have done on the Fox! As soon as the graphics are available on Callie's website, I plan on picking them up. I have not seen them yet though. Keep up the great work and I have enjoyed following along.
    I am working on a solution for a handle and should have something by the end of the week. I think I will make a few sets and post them on the classifieds if there is enough interest. I put the wings on a off a couple times last night and the stand works great to support the airplane during setup.
    Spookyeng,
    Thank you sir, for the kind words on my paint job.
    The graphics for the "CITIZEN WATCH", are ready from Callie Graphics , you just have to ask for them because they are not on her web site yet.
  • Spookyeng
    Originally posted by t33jetman View Post
    Outstanding concept and work. You are the Man on this project. I like it!
  • t33jetman
    I posted also on RCG as well.
  • Spookyeng
    I posted also on RCG as well, but just in case some don't check that thread, I thought I would share it here as well! Finished the transport and setup stand today and finally got a chance to get it assembled. A little file needed in the inside corners due to the 1/8" endmill leaving a 1/16" radius. Quick work with a square file and everything fits together very nice and I am happy with the design and the results. I designed it in mind to use 1/2" thick EDPM foam with a 1" width with self adhesive back. I like it because it is firm but flexible. We use it at work often and the adhesive is pretty strong! Time will tell out in the sun and use throughout the flying season, but feel confident its a good solution for padding.
    The design was to leave the middle open so you could assemble the airplane in the stand and that is shown in the pictures. There is plenty of room for batteries, the ones pictured are 6S 5000 mAh and I still have room for more. Also, there is room for a small charger and power supply. Overall, I am happy with the result and it meets my design intent. With the tab and lock construction, should be very strong too.
    Now that the main design of the stand is complete, I will get back into CAD and finish up the handle to help in carrying the airplane from the truck to the field. That is the reason why the two top middle holes on each upright do not have wood dowels. I will source some quick release pins or thumb screws and nut plates in the carrying handle.
    Anyways, they say pictures speak more then words. Fun project and the Stepcraft 840 worked flawlessly! Talk soon.
  • t33jetman
  • t33jetman
  • t33jetman
    Wait before you order this set from Callie because I need to give her some corrections that need to be done on the wing decal and the wing tip decal , elevator decals.
    The Black and Red strips for the wing tips, elevator tips, and top of the rudder are wrong from her right now . Unless you want to paint them on yourself like I did. ( I will send her the correct figures for these)
    The rest of the decals are OK from her.
  • t33jetman
    He is my update from over the weekend.
    Not much, just finished both sides with decals and painting the Black and Red strips on rudder.
    The wings I might do something different on how I paint them.
Name:	fox glider 2.jpg
ID:	172110Click image for larger version
Name:	fox glider 3.jpg
  • t33jetman
    Originally posted by rzing View Post
    Hey Jetman, If you don't mind me asking, where did you get your graphics from. They look fantastic and so does your paint work!
    CALLIE GRAPHICS
  • rzing
    Just a really nice job!! :Cool::Cool::Cool:
  • t33jetman
    Dutchwhite001
    Thanks man, for the kind words.
    I've flown all my paint jobs. Just dont fall on love with them.
    I'm just a street artist I guess.
