Official Freewing 64mm F-8 Crusader Thread
  • Ccorah
    Hi everyone. My dad and I bought this plane kit from RCMotion w a futaba T6L radio and futaba r3106gf receiver. I think we must have the throttle calibration wrong because this plane does not have enough power to fly. It cannot climb. Glides to ground or stalls. The throttle on the receiver only activates the ducted fan in the last 30% of the throttle throw. Does anyone know how to recalibrate it to generate full throttle and be progressively responsive thru the full range of the the throttle stick? I can’t find anything.
  • gerardkessels@wbl.nl
    Hi I bought this nice plane. Because its verry nice and have seen it when i was in the navy. I build some leds in it before I glew it together. Try to setup as3x wit ar635 but did not work with this elevon setup.
    the only thing to.do is to fly .cg was not easyJet litteratuur november heavy
    love it.
  • tomcat3112
    When I first linked (bind) the transmitter to receiver My throttle worked in reverse and elevator and ailerons only worked kitty corner on the stick control. I then attempted to re-link again and lost all throttle and engine but still had kitty-corner on l's. ?????
  • The Sheriff
    Originally posted by Alpha
    ... and the next project will be a turbine powered RC 1/4 scale hovercraft. With lasers. And a boombox.
    Stumbled across this little nugget while skimming through this thread to see what mods, if any, people are doing to their F-8s. I can't seem to find this on Motion's site, not even in the discontinued. I picture a mid 2000s Tool concert seamlessly transitioning from grass to lake. Any update? I mean, "everything is coming, eventually" right?
  • RCGuy83
    I wanted to share a little carbon fiber mod I did to my F-8. I was reinforcing an RC boat with carbon fiber cloth and cut a small piece to resin in place for protection on the F-8 Crusader.
    Click image for larger version  Name:	IMG_0786.JPEG Views:	97 Size:	81.1 KB ID:	222581
    Click image for larger version  Name:	IMG_0782.JPEG Views:	58 Size:	47.6 KB ID:	222582
    I drew up a simple AIM-9B that prints in less than 90 minutes total. A little bit of paint and they'll look great. I also liked the real F-8's quirky fuselage mounted Sidewinders, reminding me of the English Electric Lightning.
    Flight handling isn't noticeably affected, and the missile easily clears both my hands during launch and the grass during landing. Download the STLs, attached. Print upright, glue or pressure fit the Tip to the Body, trim, paint, install. I used a 6mm Brim, 0.2mm layer height, 10% infill, with Support.
ID:	155379Click image for larger version
ID:	155378Click image for larger version
    Originally posted by Blaze0021
    This is a 4S flight video of my Freewing F-8 Crusader EDF Park Jet, modified from 3S.
    Thanks for watching!
    I missed your post, Blaze0021, but I like your mods and video!
  • Blaze0021
    I upgraded the stock 30-Amp ESC to a Predator 40-Amp with 3-Amp SBEC and also shortened the ESC wires to scoot the ESC as aft as possible to balance the Crusader to the factory recommended CG. The battery used for the flight is a Roaring Top 4S 1800mAh 70C Lipo which is positioned as far back as possible, butted up against the rear foam compartment wall. The 5-blade EDF fan unit and 2627-4500kv brushless outrunner motor are both stock.
    Checking in with Motion RC, I was advised that the stock motor and fan are both 4S-capable, but I would need to upgrade the ESC. I’ve been flying my F-8 Crusader on 4S with no issues for a while now after I found the 3S performance to be lacking in power, especially at altitude. I thought I would share my results.
    Hope you enjoy the video and flight footage!
    MODIFICATIONS:
    1) Predator 40-Amp ESC with 3-Amp SBEC
    2) Minwax Satin Finish Polycrylic Triple Coated Airframe: Maximum paint and finish protection.
    3) JB Weld 5-Minute Clear Epoxy Coated Air Intake: For belly landing abrasion protection.
    TRANSMITTER, RECEIVER, & SETUP:
    Transmitter: Spektrum DX8 G2
    Receiver: Lemon RX DSMX 7-Channel Diversity Stabilizer / Receiver
    Rates Used: 85% Aileron / 32% Expo, 100% Elevator / 16% Expo
    Battery: Roaring Top 4S 1800mAh 70C
    Throttle Timer: 3:10 Minutes
    Total Flight Time: 2 Minute(s), 48 Second(s)
    Lipo Final Voltage: 15.03 Volts out of 16.80 Volts (~3.76 Volts / Cell) at 22%
    ADDITIONAL INFO:
    Camera: iPhone 7 at 1080P / 60 FPS shot on an Action Mount Head Cam
    Wobble!!! Just crooked air.... ;) Embraced!!!
  • EA-6B Geek
    Got any videos? I'm contemplating buying one with LG, no gyro, and using 1800s, but all the videos I've seen are hand launches.
    Its a shorty, but watch this one. 4s with the retracts from the 70mm F-104. Embrace the wobble!
    No video... I was flying at our local elementary school by myself on a Saturday afternoon. So no one was around... Sorry!
  • Valkpilot
    Originally posted by Hardway
    I stuffed an A3-L in the F-8, and the wobble is gone when on... Using an Admiral 1600, but I do have gear on mine and that may lower the CG and stabilize the chiming (wobble)… :Thinking:Think like a keel on a sailboat...
    That's funny, my F-8 wobbles too. After a while I stopped worrying about it, and have embraced the wobble.
  • Valkpilot
    What do you guys expect? Both the F-104 and F-8 were Engines with wings strapped on and a guy stuffed into them.
  • DzlDk
    Mine came in yesterday! I went w a regular Spektrum 400 rx and 2200 4s... i may get smaller batteries.. see how she flies first
  • Bcool831
    Flew 4 more packs today and 3 through my f22 raptor. I really enjoy this plane.
  • Bcool831
    Did you do a bind on the RX before hooking everything up except the power?
    I figured it out stupidly I did not calibrate throttle. I love this jet. Easy to fly and a blast.
  • Valkpilot
    Originally posted by Bcool831
    Hey guys. I built mine last couple of days. Im using dx9 tx and ar636rx. I cannot get the df to run. I have the throttle trim lowered when I power up tx and then plug in flight battery. It beeps 3times and then makes weird tones but the flight surfaces do move correctly but no motor functions.
    Any ideas?
  • EA-6B Geek
    Originally posted by CFIT rob
    Mine wobbles as does my F 104. F8 has admiral stabilized rx, F104 has lemon stabilized. I have my rx's set up so i can turn stabil on and off. They both wobble with stabil off if there is the slightest wind. With stabil on they still wobble. Have the same lemon rx on a 50mm blitzworks deltawing edf that flies like on rails with stabilizer on. On launch the stabilizers work like a charm. Could it be the servos are not fast enough react to stabilizer?
  • Bcool831
    Any ideas?
