Trunion Nose gear pin removal on Stinger 90mm EDF
  • FB111A
    • 11
    • Hernando Beach FL
    I have a bent nose gear pin on the trunion & need to remove it. I have loosened the set screws on both sides & the pin only comes out 1/2 to 3/4 of the way. Do I need to retract the gear in order to remove it ???
  • ryramZ
    Pilot Ryan
    • Dec 2012
    • 814
    It can't come out while the circlip is still in the strut pin. It will need to be retracted to see the circlip. You might be able to pull it out the other way if it's not bent to bad. The pin should rotate in the trunnion and not have set screws in the trunnion.
    • bill34207
      Jet Junkie
      • 455
      • Bradenton, Florida
      Best bet is to split the retract and pull the whole trunion. You will need to pay attention and not drop/lose any of the small parts (I do them over folded towel to absorb any bounce "just in case") but once out it's pretty easy to slide the pin through.
      Just noticed, you are in Bradenton. I can show you how if you need it.
      • FB111A
        • 11
        • Hernando Beach FL
        Thank You Pilot Ryan. I will retract the gear & see if I can remove the e clip & pull the pin out.
        Yes Bill I live in Bradenton of of Cortez & 75th St W. I am also a member of the SRQ flying field. I haven’t been to the field in a while because of family commitments in NY. If I have a problem removing the pin I will reach out to you here on hobby squeak. Thanks Guys I appreciate your help
        Paul Sweeney
        • bill34207
          Jet Junkie
          • 455
          I haven't been to the field since Irma came through since the county has Rothenbach park closed to the public and is using it as a staging area for storm debris processing. Hoping it will be reopened by the new year. Meanwhile I've been flying at the SSF facility out next to the speedway.
          • FB111A
            • 11
            • Hernando Beach FL
            Wow Bill I had no idea the field was closed. Give me a call when you have the chance. My cell is (347) 782-7625
            Paul Sweeney
            • bill34207
              Jet Junkie
              • 455
              Got your number written down. Will give you a call this evening after I get home from work. 5:30 ish
              • seaviper
                ATC retired
                • Aug 2016
                • 1092
                • Philadelphia Mississippi
                My birds have the same nose gear. I just remove the gear, disassemble the retract, remove pin, and re-assemble. I have actually done this at the field. It takes very little time. Just be careful not to lose the little screws in the retract and make sure you get everything aligned properly. The servo wire has to fit in that little groove inside the retract. Take your time and do this over a solid surface so you can find any dropped pieces.
