F9F
  • #21
    RE: F9F
    Ok came home did some more adjust to elevator and added little more weight and got her up !!!! 3 1/2 minutes brought it down and 14% on battery . So I think I finally got it .Have a new fuselage on the way to make it new again !!!! Next Sunday I will try again and get some film.
    I added three blocks of 1/4 oz form Hobbico to it .In the nose behind the cone
    Bryan
    But Crashing is Landing
    • #22
      RE: F9F
      Greetings H64,
      What was the total weight, like 3 oz.'s??
      Bill L.
      in Okla.
      • #23
        RE: F9F
        Originally posted by Hippie 64
        Here is the ugly fact !!!!! http://vimeo.com/112757917    I barly gave it any up with very low rates . Also as soon as I say the climb start I tried nosing it over .
        [hr]
        Loneflier sounds like you live in my area , upstate SC .
        Hi H64-No, I live in North Alabama. Wish some of you guys were closer. It would be fun to get together and do some flying.
        [hr]
        Bryan
        Sounds like you got it worked out now. On my MIG, I mainly just adjusted the elevator trim to more down, and was able to get it to fly well. It has been so long since I built my F9F, I can't remember for sure if I added weight, but I think I did. It is glued in behind the nose cone if I did.
        • #24
          RE: F9F
          Rktr it's only 3/4 oz total . The blocks are ingraved with 1/4 and used three . Adjusted a small amount of down neutral and tried it . Was a little too much down so landed and took a little out but still had some down in it . Got it leveled run 3 1/2 mins , battery showed 14% so I was satisfied .
          Anyone reading thru these post please take in mind this is with the landing gear added . All research I did for info starting out was without the gear , it's all I could find .
          Looking forward to getting new fuselage in to put her back pretty .
          Bryan
          • #25
            RE: F9F
            Greetings H64,
            Wow! Only 3/4 oz.!! That's great.
            I know you might have mentioned it but, which LiPo did you use?
            Bill L.
            • #26
              RE: F9F
              Hey Rktr I'm using the 3s 1600 . It's slide up against the nose gear . I did double check and the info on my weights is right .
              Bryan
              • #27
                RE: F9F
                Greetings H64,
                Thanks Man,
                I really want to get another one of these birds and give it another go, wish it would go on sale......
                Thanks,
                Bill L.
                in Okla.
