I’m having trouble getting my speed controller to initialize the fan anybody got any comments that might help I would surely appreciate
T45 Speed controller initialization
Tags: None
If you are using Futaba (or other that uses Futaba's direction and value range) You may need to revere throttle and/or increase from default (100%) throttle range to max ATV/Endpoint adjustment values.
Default travel range for JR/Spectrum (and most other brands other than Futaba) is appx 130% of Futaba's default range. JR/Spectrum has 120% as max ATV, Futaba allows up to 150% which comes out about the same max limit as JR/Spektrum's 120%
Most ESCs will initialize with the Futaba default range (if you use the correct direction) But some will not.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
.png)
