I just recieved the freewing 70mm f16 any suggestions for starting point set up for Eagle A3L gyro
70mm F16 freewing Gyro starting point
Set up is a breeze assign s bus led to a rotating knob this way you can set gain in flight if your using the different modes all gains will be adj in flight from this knob all other set up info is in the instructions you can also leave the mods lead off then gyro always on no on off no mods change -
Great info but I left out I am using spectrun DX6 I dont have knob but a 3 position switch I will set up so I can switch gyro on or off but with that I will need starting point that might get me close thanks though I should have given all infoComment
