70mm F16 freewing Gyro starting point
  • RC Oldy
    Hobby Squawk Pilot
    • 44
    • Farmington MN
    I just recieved the freewing 70mm f16 any suggestions for starting point set up for Eagle A3L gyro
  • hotrod23t
    jim jets
    • Nov 2017
    • 312
    • EUSTIS FL.
    Set up is a breeze assign s bus led to a rotating knob this way you can set gain in flight if your using the different modes all gains will be adj in flight from this knob all other set up info is in the instructions you can also leave the mods lead off then gyro always on no on off no mods change
    • hotrod23t
      jim jets
      • Nov 2017
      • 312
      • EUSTIS FL.
      Or due you have a specific question
      • RC Oldy
        Hobby Squawk Pilot
        • 44
        • Farmington MN
        Great info but I left out I am using spectrun DX6 I dont have knob but a 3 position switch I will set up so I can switch gyro on or off but with that I will need starting point that might get me close thanks though I should have given all info
        • hotrod23t
          jim jets
          • Nov 2017
          • 312
          • EUSTIS FL.
          I would start at 50 percent if you get wing shake turn it down a little my avant I and my a10 seem to like Camille less than 50 percent hope this helps
          • hotrod23t
            jim jets
            • Nov 2017
            • 312
            • EUSTIS FL.
            A little lees than 50%
            • RC Oldy
              Hobby Squawk Pilot
              • 44
              • Farmington MN
              thanks Helps alot I will give it a try
