Blohm & Voss BV P.215
  • Flyingaceaircraft
    • Jan 2015
    • 18
    I know there have been several scratch built conversations online over the years on the German Pod Fighters and advanced designs that were slated for operational use in 1946... and I have always been interested in these designs.
    I just finished and flew a scratch build of the Blohm & Voss BV P.215 - after the first flight - the crappy EDF that I used was running rough - so I cut it out and installed the Freewing 64mm fan that is in the Stinger 64 after it arrived from Motion RC.
    The result is that it flies great with the new motor setup - I am running 4S 1800 mah packs with 30 C discharge and a 100 amp speed controller. It tops out around 85 mph  - not as fast as the high speed Stinger 64 but close.
    Very stable and fun plane to fly - it looks unique... so I have already started on a larger version that will be either a single 90 mm fan or twin 70 mm. I did drawings and cut out foam insulation for the design. The smaller one that is flying has a skim coat of epoxy resin all over for strength. All up it weighs 1.5 lbs. ready to fly.
    I would love to see this done in a kit... it is so unique and it is stable and flies very well. I guess it is too unorthodox to be popular... so I guess I will have to keep building my own.
  • Loneflier
    • Aug 2013
    • 603
    • Huntsville, AL
    RE: Blohm & Voss BV P.215
    Very cool jet there! I personally would love to see more of the early WWII and cold war jets available. Nice work there Flyingaceaircraft!!
    • Flyingaceaircraft
      • Jan 2015
      • 18
      Got some useable video of it in flight today.
      http://youtu.be/G_NzbefchBQ
        That is not an easy aircraft to design well. You did a great job, congratulations!
        • Briggs79
          • 27
          old is gold. lovely plane.
          • Banditone
            • Jun 2018
            • 38
            Where an I get a set of plans for the Blohm&Voss 215?
            • Banditone
              • Jun 2018
              • 38
              Hello flyingace
              Have a 90 mm edf. Would like to build the bv 215, you have any plans that I can purchase from you?
              rich
                Originally posted by Banditone
                Hello flyingace
                rich
                Sorry to say that you'll most likely not get a response because he hasn't been on for better than 9 months:(
                • Banditone
                  • Jun 2018
                  • 38
                  Hello still looking for a Blohm & Voss 90 mm 215 plans or a kit
