STL files at: https://www.thingiverse.com/thing:4091983
Freewing Eurofighter Typhoon V2 90mm EDF Thrust Vectoring Jet
Well, the V2 doesn't get much love any more, so I made mine some improved push on "skins" for the exhaust nozzles. They are very light and just push over the nasty looking foam nozzles. I am biased, but I think they look a whole lot better.
STL files at: https://www.thingiverse.com/thing:4091983 -
I'm thinking the same thing. I just wish I knew what the guy's saying. I had the last V2 and sold it. The next guy never flew it and and another friend just picked it up. (I got a little excited when I saw this video.)Leave a comment:
Push-on 3DP overlays for the ugly foam VT nozzles. They are thin so be careful when printing and fitting them. Also be sure they don't interfere with the VT range of motion.
This is a push-on overlay for the rather unattractive thrust vectoring (TV) nozzle on the V2 Freewing Eurofighter Typhoon. Print as light as possible since it does not bear any load. The cut-outs accommodate the ball joints for the TV pushrods. It's a fairly tight fit so ensure that there is no flash on the print, which will prevent it going on all the way. It's thin, so you may need to adjust your slicer parameters accordingly.If using the TV moveable nozzle make sure that you still have the full range of movement on your TV nozzle.There's a slightly thicker one available if your slicer/printer won't handle this one. It is athttps://www.thingiverse.com/thing:4101139There is also a replacement nosecone. It has a cut-out for installation of a magnet to hold it in place instead of gluing it on. I printed it with 1 wall and 5% infill to keep it light..Leave a comment:
I would agree, and that SUPER annoying drop down menu is just that...Leave a comment:
Motion just did a big change to their web site Friday, I would say it's a glitch.Leave a comment:
Not sure what to make of this. I check every so often, and normally it reads "Discontinued"
Now indicates "Out of Stock" and the "Notify Me" button is alive.
Is this just a glitch in the Matrix, or is it really coming back? Looks like a totally new website.
I need parts...
VR
https://www.motionrc.com/products/fr...nt=19056264710Leave a comment:
How much do you want for it? Send me a PM.
I am more than likely going to sell the Hobby Lobby version.
When I bought it, I was told its a V2. There are several of variations of this model, depending upon which vendor brought it to market. Gear, Power (EDF Blade/KV), Metal Canard Bellcranks v Plastic, Battery Type/Configuration, Removable Wings/Vertical Stab, Actual Rudder, Gear Doors, Gear Door Material, how the Canopy attaches. Most of the changes were nice upgrades, making it a more desirable model. The Freewing V2 (or V3 it seems to me) sold by Motion, is a very different animal, compared to the Hobby Lobby one shown.
I will never build or fly this model.
I bought it sight unseen, and the seller nor myself were aware how many versions were on the market back in the day. I have read there is no V3, but have seen it written in other places. Also seen V2.1, V2.2, and V2.3
WHO KNOWS WHAT IS ACTUALLY CORRECT!!!
Bottom line is, none of it matters now anyway!!
I would like to see an updated even further, more modern version of the Eurofighter! Just like every model ever made, some will love it, and others won't.
Here is my favorite video, want to learn how to fly like this!
VRLeave a comment:
Interesting for sure. The site is not Motion so they may say V3 and it really isn't any different than the V2 Motion had. The motor size and kV, 130A ESC, gear doors, struts, metal trunions, metal gear servos, etc were all on the V2.
In fact in the description it says "If you want the ultimate in thrust vectoring maneuverability combined with top of the line scale appearance, look no further than the new Freewing Eurofighter Typhoon V2 90mm EDF Jet.".Leave a comment:
I wouldn't sell it. That one has a much better ducting, thus higher thrust to weight ratios are achievable and better flight times too.
This is what I am trying to get across, its NOT a V1, it has actual servoless landing gear, but does have a 6 blade 1750KV 90MM EDF. It does have a foam NLG door. It does have the awful Pilot. It has glue on drop tanks, it does have no MLG doors. It does have the plastic canard bell cranks. It has the early, more magnets forward located, canopy. Lets call it a V1.5!!!You will likely be doing yourself an ill favour if you get rid of the V1. It may not have as many bells and whistles as the newer V2, but it had a much cleaner duct and was lighter so it flew better for the most part. You just need to upgrade the 'annoying parts' (change old servo actuated retracts by 'e-tracts' if it's truly a V1, get better actuator arms for canards, replace servos motor and esc, etc... mostly pretty minor stuff!).
Oh and it has the weird, slanted battery compartment for two three cells with Deans connectors. This model in my opinion should go to a collector.
EDIT, it also has NO carry through spars, none. This has the glue into a molded channel on the bottom of the wing, that does insert into a small portion of structure in the wing root area.
VRLeave a comment:
You will likely be doing yourself an ill favour if you get rid of the V1. It may not have as many bells and whistles as the newer V2, but it had a much cleaner duct and was lighter so it flew better for the most part. You just need to upgrade the 'annoying parts' (change old servo actuated retracts by 'e-tracts' if it's truly a V1, get better actuator arms for canards, replace servos motor and esc, etc... mostly pretty minor stuff!).Leave a comment:
More fuel for the fire...
https://www.skybluerc.com/new---supe...-jet-989-p.asp
This one also has more changes that are not one the last ones sold by Motion. When I bought the Freewing one NIB shown above, the seller said Motion told him on the phone it was the last one in stock, never to return. That was 2018.
VRLeave a comment:
The manufacturer on the box had a V2 on the one with gear doors, updated power and a couple other things so really just V1 and V2. Those that claim there were other versions go by other small updates done to all planes such as changing from the metal hub multi piece fan to the solid plastic fan or from outrunner to inrunner on the more current FW EDFs. None of those were designated V2...Leave a comment:
VRLeave a comment:
