  • Olivier_
    • Sep 2023
    • 36
    • France
    Originally posted by Olivier_
    For the Mirage Tiger V2: Do you confirm :
    • the values in the attached photo ?
    • the center of gravity 520-530 mm from the rear of the plane ?​
    I also asked the Motion technical department, here is their response :
    "I would not use the rates in the book as they're way too high/sensitive. I highly recommend setting your low aileron rates to 25-30% with at least 35% expo. This model has a very sensitive roll rate so you will most likely never need anything higher than low rate. Elevator I recommend 65% for low with the same amount of expo as aileron. "
      • 5426
      Interesting in more than one way. First what you posted as rates is not what was in my instruction manual and not what is in the current manual at the Motion RC site. Second, as noted throws and expo are usually a personal preference. Third, while it's great that you got a response from "someone", have they ever flown a Mirage or are they going by generally what they have heard or what they use for most aircraft. The Mirage does not fly like most aircraft. What I like will crash your plane as I like super high rates, that's why I didn't answer. I also like a tail heavier set up.
      I said I've had 5 and just orderd #6.... Yes, another Mirage. 😉
      • Olivier_
        • Sep 2023
        • 36
        • France
        How did you manage the refueling pole (photos attached) ?
        I don't find it practical to glue it permanently because it will interfere with the carrying case.
        I'm going to think about a removable system....​​
          • 5426
          I glued it in.
          • Olivier_
            • Sep 2023
            • 36
            • France
            I'm looking for a first "beginner" setting so as not to crash it upon takeoff, that's my fear. This is my first fighter plane and delta wing plane.
            I fly with AS3X and SAFE from Spektrum, which should limit bad surprises.
            What additional configuration do you want to do with a 6th Mirage ??
              • 5426
              Nothing additional that I haven't done with another. Even set up identically each plane has it's own personality. And I may sell the ONE I currently have as it is about eight years old.
              • Olivier_
                • Sep 2023
                • 36
                • France
                there you go, done !
                to see if it holds up in flight !
                  • 5426
                  Well done!
                  • Olivier_
                    • Sep 2023
                    • 36
                    • France
                    Where are these parts attached?
                    I don't see anything on the instructions.​
                      • 5426
                      Vertical stab towards the top.
                      • Olivier_
                        • Sep 2023
                        • 36
                        • France
                        I finally found it by looking at the photos on the website.
                          • 5426
                          I have a like new Mirage kit+ for sale on RCG, two flights on it, no damage at all, no hanger rash. Selling without the 2150 EDF or ESC but I could add a 9b 1920 EDF and non reversing ESC cheap if someone is interested.
                          • Fredardi
                            • Oct 2019
                            • 54
                            • Palermo,Sicily,Italy
                            Hello , I can complete my radio settings on my Dx9 Black. I set to elevons and everything work fine but if I want to modify the elevator throw differently than my aileron throws it will modify also my aileron throws .I can't modify both differently .I also try on Elevon B but still the problem .I use a AR 620 Spectrum receiver.Any suggestions ? Thanks
                              • 5426
                              Instead of changing it with servo travel do it in the D/R menu.
                              • Fredardi
                                • Oct 2019
                                • 54
                                Thank's I'll try this way.
                                • kallend
                                  • 1877
                                  Just thought I'd repost links to the 3DP nozzle and cockpit parts for the Mirage:
                                  https://www.thingiverse.com/thing:6165664
                                  • Fredardi
                                    • Oct 2019
                                    • 54
                                    Yes as you said I have solved thanks .Done my maiden plus other 6 flights and is absolutely a blast to fly ! Only one thing I have to set better its when I pass at full speed it's like it behave with the ailerons and does not go straight but the wing do small mouvements on straight like going from left to right and from right to left it does not make my wings go level.I check the ailerons and they are trimmed perfectly as also the rudder.I set the ailerons at 35% rate with 35 % expo...Maybe I have to add more expo ?
                                    • SanExup
                                      • 912
                                      • Western Wy.
                                      Fredardi Are you using a gyro? If so turn the gain down.
                                      • Fredardi
                                        • Oct 2019
                                        • 54
                                        No no gyro installed
                                        • SanExup
                                          • 912
                                          • Western Wy.
                                          Maybe add one! Expo only helps if it's you that is moving the stick.
