Originally posted by Olivier_
View Post
"I would not use the rates in the book as they're way too high/sensitive. I highly recommend setting your low aileron rates to 25-30% with at least 35% expo. This model has a very sensitive roll rate so you will most likely never need anything higher than low rate. Elevator I recommend 65% for low with the same amount of expo as aileron. "
Maybe add one! Expo only helps if it's you that is moving the stick.
