The new reversing 100A in the Gripens but on low timing to lower the amps,116-117. Reversing 100A in the Avanti and praying each flight it doesn’t smoke. It’s easy to touch the front of the ESC and it doesn’t feel hot after a flight. The Mirage has a Hobby King 100A.
Freewing Mirage 2000C V2 “Tiger Meet” 80mm EDF - Official Thread
I have one of the fan units. I can't make up my mind whether to use a 120 amp or not. If they could only stock more esc's and fan units. I know I can buy them elsewhere, but I'm not in a hurry to get it. Though I keep wondering what they would be like in the A10.Comment
Motion has a remarkably large number of "out of stock" items right now, across the entire range of aircraft.
Which is why I've started looking elsewhere.
Not directly comparable, but similar:
I run the FMS PRO units in all my 80mm EDFs including the Mirage. These units seem to have similar characteristics to the new Freewing fan (2.8 - 2.9 kg thrust installed, 110 - 115 amps on an HRB 6S pack with stock ESCs).
I've recently flown all of them on SMC 6S HV packs with noticeable performance increase but haven't made a current measurement yet. However, thus far there have been no issues with the ESCs.
YMMV of course.Comment
Hello,- To get 6S, can I use 2 x 3S batteries in series ?
- The battery compartment sizes given in the manual are: 200 x 55 x 56mm. Are they correct for V2 ?
- I have spektrum 3S – 4000 mah – 30c – 290gr – length 140mm – width 23mm – height 42mm. So 2x3S are 46mm wide and 580gr.
- Do you think this is ok ?
Olivier
Hello
I just received my Mirage V2.
Here are the photos of the ESC and EDF compartment.
I note the following design weaknesses which are surprising given the rest of the quality of the product :- screwing and plating the ESC into a 3 mm wooden plate: random attachment (look at the photo), not very secure and very risky in this location: just in front of the EDF.
- To remove or change the ESC, you must remove the ventilation grille. Not practical at all: a magnet or screw fixing system would have been more judicious.
Most if not all FreeWing planes attach the ESC that way. I add a dab of the white tube glue to the tops of the screws. Most people don’t and it works.
You don’t need to remove the grill. A long screw driver between the slats works.
This “tinkering” to secure the plane remains disappointing in view of the rest of the quality of the plane. We can clearly see that this part was neglected by the manufacturer.Comment
You seem annoyed by my remarks. Good for you if you settle for mediocrity with glue left and right.
I maintain that 2 small tapping screws to hold a 120g ESC in a 3mm wooden plate is a neglected and disappointing solution at this location of the aircraft.
I add that I didn't even need to unscrew them with a screwdriver, the plate came off with little resistance.
Freewing too, can and must improve, and thanks to its customers like you and me.Comment
Actually I am… the engineering flaw of having to remove the cheater grid to unscrew the ESC when a screw driver fits through the slats just isn’t. Yes it may be easier but I would never call it a design flaw. As far as the wood plate, just about all these use it and I don’t recall anyone saying they lost a fan because of a screw. Could it happen, sure, but you just got this and I think you’ll be overly critical when you encounter something like a loose retract mount or servo arms at odd angles, not counting any number of possible issues.
Again good luck with your Mirage.Comment
I'm going to end up believing that you have financial shares in freewing to dispute the evidence ?? 😀😁Actually I am… the engineering flaw of having to remove the cheater grid to unscrew the ESC when a screw driver fits through the slats just isn’t. Yes it may be easier but I would never call it a design flaw. As far as the wood plate, just about all these use it and I don’t recall anyone saying they lost a fan because of a screw. Could it happen, sure, but you just got this and I think you’ll be overly critical when you encounter something like a loose retract mount or servo arms at odd angles, not counting any number of possible issues.
I repeat : small poorly screwed tapping screws, moreover in wood to maintain a 120g ESC which will also gain inertia by the acceleration forces and is not up to par with the rest of the plane. Why did Freewing provide magnets for the nose of the plane or for the tanks? No doubt because it is more practical for transport or for many other reasons which are indeed valid. This concern for quality is not found for the ESC, because nothing is provided to facilitate removal, replacement in the event of breakdowns or for people who wish to use another ESC. And the same for the immovable grid which is absolutely not welcome not only for removing the ESC but, worse, for installing and then adjusting the new ESC in the location. We can clearly see that Freewing was not at the end of a quality design in this area of the plane.
Good luck also with your Mirage.Comment
