Freewing Mirage 2000C V2 “Tiger Meet” 80mm EDF - Official Thread
  • JejeMTP
    I flew my mirage v1 with at least 30% expo and 5mm on the aileron and i feel it was still touchy (enough to fly but i planned to reduce throw before i crashed it).
    I also have a question because the 3rd flights i've done i found it was nose heavy : with a 690g battery as far backwad i could (removed foam after maiden), my cg was a little forward the 530mm from the end of the fuse with gears retracted.
    When you check the cg of the plane, you'll do it with landing gears outside ? Where is your cg ? At 520mm or 530mm ?
  • FlyBoy90803
    I just bought the mirage 2000 v2 im really excited about this jet. I have read about the throws on aileron being really sensitive, does anyone have a recommendation for how much throw and expo I should use on all 3 axises to maiden my jet?
  • Rucky
    Hello pilots so I have spiced up my Mirage 2000.
    Download the files for the 3D printed Freewing Mirage 2000 Upgrades / Scale Details by rucky Plex;)
  • roys001
    Hey Steve, it shouldn't take more than the "typical" amount of down elevator to keep the Mirage's nose upward while inverted. I'm curious if you're flying with any reflex, and with what battery?
    I’m Flying with the Admiral 5000 pushed all the way back between the intakes. It was the same when I run the yellow admiral 4000. For what ever reason the one I have needs weight in the back to balance where the other pilots are flying at. It is a great flying airplane. I was just curious about the lead I was adding.
  • roys001
    We have at least 4 mirages at our field including mine and no one had to add any weight, and I'm running a 4500 roaring top with the a/b from the geek. Sepulveda basin in the san fernando valley, come and check.
    That’s were I fly too. I can try taking lead out of the engin hatch and see how it works but even as it is the plane seems nose heavy. When I roll inverted it takes a lot of down elevator to level it out and a fast roll is kind of a mini barrel roll.
  • JohnVH
    Maiden on a buddies new Freewing Mirage 2000 Tigermeet!
    That's the best when you have many options like that, just makes life that much better in my opinion :Cool:
  • Jackcannon
    Welcome to the squawk, this plane does look like an amazing flyer
    Thanks rifleman. She really is a lot of fun. I fly the 90mm Venom and the A4 and the Mirage is like an F1car zipping around compared to them. Between the three, I’ve got a broad flight envelope.
  • Jackcannon
    Maiden flight today went very well. Put 3 batts thru her, fluoreon 4500s with the timer at 3:30. Great flier, very fast! On final she’s very hard to see, so I’m going to add some “metal” to the leading edge. Thanks Motion RC and Freewing.
  • Quickstop
    Originally posted by roys001
    I've got the plane built and it is a wonderful looking bird. I have an gyro in it that I put just behind the battery bay which meant I had to mount the radio all the way. I've also added the center AB lights from RC Geek. I put the Admiral 4k battery in as far back as I could get it and could not get the plane to balance to the specs in the manual. I had to add led to the back of the plane. My question is, has anyone else had trouble getting the plane to balance?
    You have to tuck the battery back in the fuse a little.
  • roys001
    Here's the video...
  • Rosytime
    I maidened mine today. Boy this jet is fast. I had too much aileron throw and cut it down after landing. I also put some more expo in it the ailerons. Second flight was much better although the wind was knocking it around. I'm using a Jetwerx 4000mah 60c and it balances a little nose heavy with the gear down. Gear up is fine. When banking the wind can really bounce it around. I am impressed with the power this set-up has. Flying along at high Alpha and push the throttle forward and it visibly accelerates much like a prop plane. Vertical was no problem. Now to try and get it to hover if even for a few seconds. The best part is you only need to fly it at half throttle for the majority of the flight to enjoy it. My timer is set at 3:30 and I'm landing with 35% in my batteries. They were a little warm but I attribute that to the lack of cooling in the fuselage for the battery. Might need to figure a way out to get some air in there.
    Nice!!!!!
    Here's some more in-flight pictures...
    I think itll do fine personally. My f18 did well on my field where it's really rough. I'm hoping our guy who mows gets back from vacation soon. It really needs to be knocked down as it is 4 inches tall. :Straight-Face:
    How does she do on grass George? Your field looks to be cut a little shorter and smoother than mine, but not by a lot. The main wheels look good, but the nose wheels look pretty small.
