1/30 Scale Airbus A330-300 Build Log (3D Printed)
  • #41
    What he said.....
    paul
    • #42
      Thanks Paul.
      High confidence in having this ready for Jet Jam this upcoming week. Need to complete weight and balance, and try to print/rig the flap track fairings. I can fly without the flap fairings, but would give that final touch.
      • #43
        I have high confidence in you and your bird, too, Dirty Dee!
        Maximum Effort
        • #44
          I'm speechless.
          Mike
          • #45
            Thanks guys.
            Here is some more specs in the current configuration using 2x3700mAH 45C packs:
            AUW:5995g
            Wing Area: 40.18 dm2
            CWL:23.4
            TWR:0.7
            • #46
              Maiden was a success! First bit of video shared with me.
              • #47
                :) Outstanding, Chris. My congrats! Best, Steve
                • #48
                  Thanks Steve!
                  Here is the full flight video captured by Orvie (Wayne). With the 2x3700mAH 45C packs, I had a flight time of about 2 minutes, and used 25% of the battery capacity. I do think I can get 6 minutes easily with this setup. Most of the flight was between 1/3 and 1/2 throttle, and the landing was with take-off flaps, so it was a bit hot. The suspension has the springs such that they are almost fully pre-loaded when the plane is static on the ground. This coupled with the dave brown lite flite wheels made it seem like the landing was very cushioned, and there want a concern of the plane getting bounced back into the air due to built up spring energy.
                  I have some ideas about weight reduction using a 0.3mm nozzle for certain areas as well as thinning out the stringers throughout the fuselage by 0.4mm. This all would give close to 200g of weight savings. Flying with a single 5000mAH pack or changing the power setup to 4S 3700mAH with 2800kV motors would be another option, each shaving another ~360g from the AUW
                  • #49
                    Just too cool! :Cool::Cool::Cool::Cool: Great job! Jerry
                    • #50
                      Thanks Jerry!
                      • #51
                        Excellent! She flys great! Congratulations!:Cool:
                        • #52
                          Thanks! Can't wait to fly it some more
                          • #53
                            STLs now available via my Cults3D page:
                            • #54
                              https://cults3d.com/en/3d-model/game...006mm-wingspan
                              DD, BEE-EW-TEE-FULL!! Best, LB
                              • #55
                                3rd flight in. I think it's time for paint
                                borked the landing, but everything held up. ABS is pretty resilient.
                                • #56
                                  Started on disassembling the fuselage for paint last evening. I am going with the Virign Atlantic Scheme.
                                  • #57
                                    ...going with the Virgin Atlantic Scheme.
                                    DD, Well, Duh! Gonna be spectacular, no doubt, Sir. Best, LB
                                    • #58
                                      Wings are finally getting some depth with the various colors. Hoping to shoot the wingtips and nacelles with the 2-stage candy apple red this week.
                                      lots of filling/sanding/priming left on the fuselage
                                      • #59
                                        Awesome
