Su-35
  • Scrappyfly8
    • 3
    Su-35
    I'm having trouble getting the cg right on the Su-35. I have the 6s 4000 all the way forward and it is still pretty tail heavy on a cg stand. Has anyone had to add weight to the nose? Help!! Thanks..Ready for a maiden.. ))
    Welcome to Hobby Squawk!!! I have the Su-35, but it is still in the box. I hope the other guys can help you out! I am sure they will, once they see your post... Have a great week!!
    • fredmdbud
      • 451
      Is your plane completely stock, or did you upgrade some parts, such as metal ducts, inrunners etc?
        • 8835
        Are you balancing with wheels up or down? With wheels up, a lot of weight moves forward. Balancing inverted or upright?
        • Jhnybgd
          • Dec 2017
          • 262
          Scrappy,I had the upgraded metal fans in mine and had to run at least 5kmah packs in order to get CG correct.
          Still flew amazing just not a very good grass jet.
          lots of fun though.
          Freewing needs to make a larger version with twin 9bl 90mm with larger wheels and beefier landing gear,light weight everywhere else.
          • Scrappyfly8
            • 3
            Bone stock.
            • Scrappyfly8
              • 3
              So I was balancee with wheels retracted and out. It was inverted. It is strestran tail heavy both ways. I will try again tomorrow. Thanks for the replies fellas!!
              • seaviper
                ATC retired
                • Aug 2016
                • 1092
                • Philadelphia Mississippi
                From what I read (my su-35 is not here yet) the 4000 is a bit light with the new fans. If you watch the video with Alpha narrating, at the end they show weight added to the nose to counter the upgraded fans. I am assuming these are the fans in the newer versions of the kit. If so, I would use a heavier battery if able. Otherwise you may have to add some weight. I plan on flying mine with the Turnigy heavy duty 5000 packs which are heavy as bricks. But they get the job done. I will also be flying with the Admiral 5000. Usually there is about an inch difference in battery placement between those two since the Admiral is lighter.
                Also I will have some instrumentation in the nose area which will also help me with weight.
                Check out another thread here
                Here is the video. The weights are at 5:11
                  I'm running a Roaring Top 6S 6250 in mine about 10mm back from the front and it flys great and I'm getting 5 minutes with 3.7v left.
                  • seaviper
                    ATC retired
                    • Aug 2016
                    • 1092
                    Did you ever get it balanced Scrappy?
