Spectrum dx9 and avanti flaps
  • Charlesr
    Expert pilot
    • Nov 2018
    • 6
    So setting up flaps on my avanti with my old 11x was easy With the dx9 im at a loss
  • fhhuber
    • Aug 2015
    • 1476
    Find the flaps section of the menu and you may find the flaps are inhibited by default. This is done for the people who commonly use the 2 channels for aileron servo setup to prevent accidentally altering both ailerons up/down at the same time.
    • Charlesr
      Expert pilot
      • Nov 2018
      • 6
      With the ribbon type of wing aiireon and flap wiring Activation of flap mixes with retracts .The default flap works as a 3 position switch just fine its the trying to mix elevator to flap that i just cant figure out.the above when you try to activate flaps
        • 8835
        You are using the default setting for the flap switch. You must tell the TX that you have "aircraft type - 1 AIL, 1 Flap" in order to open up the flap menu. In there, you will see the column where you can select elevator compensation.
        • Charlesr
          Expert pilot
          • Nov 2018
          • 6
          Yes i know that guess im not saying right when i open the program and check the monitor the retracts are being affected ?
            • 8835
            It's likely that you've got cross current contamination in the control board or double check to make sure all plugs are seated correctly in their proper slots. You should separate out the flaps and hook them directly to the RX.
            Oh, do the retracts actually deploy or do you just see a small deflection on the monitor?
