3d Printed Part Sets - Freewing 90mm F-22 Raptor
  • Radar-Guy
    Thanks Steve!
    Here is the file for the nose strut dual LED housing. I used 1 W LED's and just wired them in parallel.
  • e4dragongunner
    Yes please !
  • C17loadmaster
    They look great! However 50 bucks for the 90 mm Viper weapons set! Are there .stl files for these??? :-)
    I’ll sell you the F-16 tanks if you want. I have an unused set... of you want
    You may be thinking of the LX Models F-22. It was a twin 70mm, but about the same size as the new Freewing 90mm.
  • D@v
    ok Pat,
    I understood that the F22 90mm had existed in another version, but no, it's a new model simply.
    thanks
    D@v
    Originally posted by D@v
    hello guys,
    and thanks for your answer on the external tanks ...
    can you said me what are the difference between the old and new version of F22 freewing kit ?
    thanks,
    D@v
    Not really sure I understand the question. Freewing has two F-22 jets. One is an old 64mm that's been around for a long time, and this new 90mm version. You can get the new one in either a 6S or 8S setup.
  • Pogo
    Tom,
    That pic is just a dirty mock-up using the wing from my crashed F-22. I will be doing a scale placement and angle when I install these on my new one coming tomorrow.
    Yeah, I figured. Glad your new one is almost there!:Cool:
    Tom
  • D@v
    hello guys,
    thanks,
    D@v
    Tom,
  • Pogo
    I will be using the wing tanks from a 90mm FW F-16. They seem to be the proper scale.
    Pat, I'm only mentioning this because you are obviously someone who cares about scale appearance- note in this shot how the back of the tank ends considerably before the flap LE , also how the pylon extends to the wing LE.
    A question too. The full-size tanks have a significant downward angle compared to the wing incidence. I wonder if this will have an adverse aero effect if copied over to our models? Must work for the big ones though...:)
    Tom
    Wheels look SO MUCH BETTER now! Thanks Frank!
    And in order to give it a little depth, I painted the raised bump on the hub black. You can see the difference between painted and unpainted.
    Go with what works! Thanks again Frank.
  • Radar-Guy
    I had the same issue with V1. Printed V2 and they are much better. Thanks!
    Thanks Pat. No need to print V3 then.
    Frank
    Originally posted by Radar-Guy
    Here is a revised version. I removed the inner rings plus the associated extrusions and draw them again, removing one of the outer circular extrusions in the process as well. Now the part comes with the inner ring properly printed (my printer simply omitted it with the first version and I didn't realize it). Please check out this one. Sorry for any inconvience it may have caused. :Sweating:
  • Radar-Guy
    OK, here is the final version (got approval from Steve after PM exchange). :Whew:
    It looks correct in Fusion though....hmmm.. very strange.
    Better but now the inner most raised ring is floating. Sorry to be such a pain...
    Click image for larger version  Name:	F-22 Hubcap V2 Layer 8.jpg Views:	1 Size:	30.9 KB ID:	170684
    Click image for larger version  Name:	F-22 Hubcap V2 Layer 9.jpg Views:	1 Size:	29.2 KB ID:	170683
    Not that I know of.
  • e4dragongunner
