F8 Crusader 64mm EDF
  • Jonesian21
    • Nov 2018
    • 3
    This is my first EDF jet and Im having issues with control surfaces. The right and left roll is fine but I have no elevator movement. The plane only comes with 1 servo for each side of the fuselage, each servo controls both the aileron and elevator. Where do I plug the servo wires into the receiver? Right now I have a Y connector for the servos into the aileron slot and the throttle connector into the throttle slot. Or do I need to configure my transmitter for a Delta or V-tail? Help Please!
  • fhhuber
    • Aug 2015
    • 1476
    You need to activate "Elevon" mix and plug one servo in the aileron and the other into elevator. no Y harness. (that would be Delta in some programming menus)
    If the closest the reverse functions get you is correct aileron but reversed elevator, swap which is plugged into which channel.
    • Jonesian21
      • Nov 2018
      • 3
      Thank you Ill try that!
      • Jonesian21
        • Nov 2018
        • 3
        It worked the first time, Awesome! Thank you sir!!
