F8 Crusader 64mm EDF
  • F8 Crusader 64mm EDF
    This is my first EDF jet and Im having issues with control surfaces. The right and left roll is fine but I have no elevator movement. The plane only comes with 1 servo for each side of the fuselage, each servo controls both the aileron and elevator. Where do I plug the servo wires into the receiver? Right now I have a Y connector for the servos into the aileron slot and the throttle connector into the throttle slot. Or do I need to configure my transmitter for a Delta or V-tail? Help Please!
    You need to activate "Elevon" mix and plug one servo in the aileron and the other into elevator. no Y harness. (that would be Delta in some programming menus)
    If the closest the reverse functions get you is correct aileron but reversed elevator, swap which is plugged into which channel.
      Thank you Ill try that!
        It worked the first time, Awesome! Thank you sir!!
