Freewing F22 with T35 Kolibri Turbine
  • ursli75
    • Jan 2019
    • 30
    • Luetisburg Switzerland
    Hi I made the F22 with Kolibri T35 Turbine and 1 Liter Platy Buss Tank. Current wight: 3625 Gramm
  • ursli75
    • Jan 2019
    • 30
    Running Test.... https://youtu.be/yg7Ig9Sm9tA
    • Patrnflyr
      • 140
      • Lubbock, Texas
      Any problems with the asymmetric thrust? Seems like the F-22, with its low wingloading, would be ideal for this conversion.
      • yf22raptor
        Love to fly
        • 75
        Looking to do an F22 with the K30 any flight reviews or info on this or success with the kolibri
        • ursli75
          • Jan 2019
          • 30
          Today maiden with Kolibri T35 works perfeckt https://youtu.be/UNgIZf4i1ak
          • ggetzoff
            • Jun 2018
            • 17
            Nice job! Gutsy maiden with the vis and ceiling!
            • ursli75
              • Jan 2019
              • 30
              Here a new video from my F22 and F22 from Julius. This is one of the best toys ever. Perfekt in slow and top speed. No problems
              • ggetzoff
                • Jun 2018
                • 17
                Urs,
                Fabulous job! No trim problems with the asymmetric thrust?
                Thanks,
                Greg
                • Patrnflyr
                  • 140
                  • Lubbock, Texas
                  I saw someone on FB who mounted a K30 all the way in the back with no pipe. I was curious how it affected the CG. There’s just a few threads on these conversions and they’re all over the web. It would be nice for a database where everybody puts their model, equipment used, specs and flight success in one place.
                  • ursli75
                    • Jan 2019
                    • 30
                    The CC is perfect and nothing to trimm. It works perfect....
                    • Birdseed
                      • Feb 2019
                      • 12
                      I’m guessing you have the turbine set at an offset to account for the asymmetric thrust.
                      how much offset do you have?
                      is the trim the same at all thrust settings?
                      • ursli75
                        • Jan 2019
                        • 30
                        You can see at the pictures wath i did. Just removed some epo parts and insert the turbine it is mabe 1cm not in line and the trust tube is in the center from right exhoust. I had nothing to trimm evertithing works perfekt. I added electric brakes at the weehls to better stop and start.
                        • Aussie1
                          Mainly turbine jets!
                          • Feb 2019
                          • 78
                          • Adelaide South Australia
                          I'm not sure whether you need Facebook to view this video, but having a K30 myself, it makes a ideal engine for the conversion of a foamy, if you can't afford the extra dollars for the excellent Kolibri engine. https://www.facebook.com/tony.hong.5...9069443772660/
                          • yf22raptor
                            Love to fly
                            • 75
                            K 30 install almost done ..did a center 40mm pipe .
                            • Evoman
                              • 567
                              I really like how the conversion turned out all while still looking the same from the outside.What are the average flight times you are getting with that setup?
                              • yf22raptor
                                Love to fly
                                • 75
                                Has a 27 ounce tank , haven't flown it yet prob 5 plus minutes easy was getting 4 min in t-45 with 24 ounce tank but heavier airframe....
                                • ursli75
                                  • Jan 2019
                                  • 30
