Official Freewing 70mm Yak-130 Thread
  • scooter genie
    This is my first. Always thought I didn't need one, until I saw how stable some of the planes at my club are with the guys who are using them. They say that once you use one, you'll want one in all of your planes, so I thought I would give it a try.
  • bill34207
    Good spot for it since it's about as close to CG as you could get it in this model. One of these days I'm going to break down and try a gyro myself.
  • scooter genie
    That's exactly how I balanced mine. I think the rates were just a little too high, and it was blowing pretty good that day. I installed the A3 super 2 by fabricating a plywood shelf above the Battery....Check it out.
  • bill34207
    FWIW, the balance point I use is about 1/8" (3 mm) behind the trailing edge of the forward plastic insert of the wing. Balanced gear down with the plane upright.
  • scooter genie
    I just noticed that the manual says 80mm, but the overview on the product web page says 72mm, gear retracted, plane upright.
  • scooter genie
    since its blowing like crazy here in south Florida, I decided to re check the cg. I was way off. I measured the cg 80mm from the leading edge and made marks at the wing root, and balanced it on my fingers for the maiden. Well, today I actually put it on my cg machine, and found it to be quite nose heavy. especially with the gear down. I moved the battery aft 3/4" and balanced it inverted with the gear retracted, Perfect balance at 80mm, until you cycle the gear down, then it gets slightly nose heavy again. I think its good to go.....what do you guys think ? The balance point is touchy....moving the battery even in very small increments, can really shift the balance considerably either way.
  • scooter genie
    wasn't able to try again today due to the weather.
  • scooter genie
    I measured the throws at the widest point inboard. I read a couple of reviews where others had the same result, and cut the low rate throw in half. I toned it down 1/3 instead of 1/2. will give it another go tomorrow.
  • bill34207
    Hmmm... Did you maybe measure control throws on the outboard end of the aileron instead of the inboard? Mine seems very manageable with throws listed in the manual.
  • scooter genie
    Maiden report : Flew today for the first time. I installed the A3 super 2, but didn't have a chance to use it. Was too busy fighting the roll sensitivity. Plane balanced perfectly. pitch was good. Took off with half flaps. She rotated off of rough grass no problem....plenty of power on climb out ! Turned into the pattern and roll was crazy. Reduced power right away....a little more manageable, set up for landing. I wanted to get her on the ground NOW ! Reduced power some more, still on the takeoff flaps. Got on the threshold, and flared to a sweet on the mains greaser ! WHEW ! Toned down the ailerons for the next flight, which should be tomorrow. I gotta tell you, I was nervous, but got her down without drama. I used the throws per the manual, but the roll rate was almost unmanageable. looking back, I should have switched the gyro on when I started having problems, but I was kinda in panic mode and didn't think to switch it on.
  • scooter genie
    Got it.
  • bill34207
    Originally posted by scooter genie
    Thanks Bill, That sounds more to my liking.
    I just thought of something (before you get carried away on travel) It was a quick measurement and had one end of the caliper on top of the wing root and the other on the bottom edge of the flap. So, it's probably a few millimeters less than that in actual travel..
  • scooter genie
  • bill34207
    Mine is set to 20 mm at half flap and 35 mm at full.
  • scooter genie
    Can anyone tell me what they have their flaps set at ? I went by the measurements called for in the manual, but there isn't much difference between half and full flap..a mere 7mm. .thanks
  • scooter genie
    I just got mine last week, and I have to say it is nice. I really like the upgraded latch for the canopy over previous models. It has a nice FAT pin to grab onto, and the canopy closes without pulling back on the pin. I told myself a few years ago that I wouldn't buy any more of these edfs until they made some improvements in quality. I'm really impressed with this one.
  • bill34207
    I've been a fan of the little 70 mm Yak for quite a while. In fact I own two of them. The original red one now has 267 flights on it. The 2nd one (ARF+) that I gave a camo paint job and XRP 13 blade fan with inrunner now has 7.
    Great flying model in both cases. However when flying the stocker after the "hot rod" it's kind of anti climactic.
    Aside from a bit of wiggle at certain AoAs, the 70mm Yak-130 is a fun flyer that can carry a big battery. Six minutes flights are possible with the 6s 4000, so in that sense I agree with you Dahawk that it makes a nice "warm up plane". Some pilots have reported it being bouncy, but I haven't seen that. Full flaps, minor power, shallow approach, greaser every time. The removable wings are a nice touch, but for those of us who don't anticipate needing to remove them for transport (or crash replacement), a bead of Beacon Foam Tac along the wing root seam helps ward away wing flex buildup over time.
    For a cheap but great looking "upgrade", I asked Callie to make decals for the det-cord above both pilot's heads. She has the file, in case any of you wanted to order a set from her at callie-graphics.com. If she could make them 10mm longer than what is shown below, they'd be perfect. But as they are, for the few dollars it cost, it adds nice visual detail to the canopy.
Name:	Yak-130 Det Cord 1.jpg
Name:	Yak-130 Det Cord 2.jpg
Name:	Yak-130 Det Cord 3.jpg
  • dahawk
    I've found the FW Yak-130 to be one of the easiest edf's to fly. and with the Red FW version, easiest to see. It's now my warm up plane when I take to the field with my squadron of edf's. Once you learn how to make a good shallow angle approach, you'll love it. I fly mine off grass and it doesn't need much runway to rotate.
  • 2FewDaysAtFlyingField
    standouts for their uniqueness. Look for that trend to continue. ;)
    I for one like that. Rolling into the field with another Mustang gets no attention. My P-38, Bearcat, and TA152 draw a crowd a create interest in our hobby again. That's just what we need. I know this is the jets forum but A Flightline super scale P-61 Black Widow would really draw interest!
