Having a problem with the undercarriage. Can't get the 3 gears & doors to cycle in the correct sequence. Is there a particular pattern to place the gear/door plugs on the board? I have purchased a new board & regardless, the same result with both boards. Main gear cycles nose stays up, or nose down & mains up. I have checked each gear individually (servo tester) and the 3 gears function correctly. Does anybody have any suggestions please?
Thanks.
Thanks.
.png)
