Freewing 90mm F104
  • M1110
    Pilot
    • Feb 2019
    • 11
    • Brisbane, Australia
    Freewing 90mm F104
    Having a problem with the undercarriage. Can't get the 3 gears & doors to cycle in the correct sequence. Is there a particular pattern to place the gear/door plugs on the board? I have purchased a new board & regardless, the same result with both boards. Main gear cycles nose stays up, or nose down & mains up. I have checked each gear individually (servo tester) and the 3 gears function correctly. Does anybody have any suggestions please?
    Thanks.
  • themudduck
    -TMD- Foaming at the Mouth!
    • 1041
    • Burton OH (near Cleveland)
    Mine's in storage for the winter so I can't peek at the connections... but it sounds like you've already checked them. I would suggest that you post on the main thread, where there have been more than 10,000 views and hundreds of posts. If you put your question there it will probably be seen by more. Did you try cycling the nose gear once manually (using a tester) to get it into the same cycle as the main gear?
    Here's the link to the main thread:
    • M1110
      Pilot
      • Feb 2019
      • 11
      Thanks Marc, will do. Tried the get them into the same cycle. No joy.
