Hi,
I have been flying and enjoying my T-45 ! Its a great plane thank you in advance. I have been using a grass field which between my skills (or lack of) and the grass field I have bent the 4mm pin in the Electronic Retract that inserts into the main landing gear strut. When they retract the wheel will not fit into the wheel well. So I purchased the Electronic Retract with 4.1mm Shaft Type B thinking I could just replace them one for one. I did not read the description well (for use used on the nose gear) and when I went back I realized that the 4 mm pin inside of it rotated 360 degrees.
But when I looked at Electronic Retract for 4.1mm Diameter Shafts - Type A it doesn't have a 4mm pin in it so the female to the strut female connection will not work.
They are both listed under the spare parts for this plane so I am not sure what to do next. I don't need the whole T-45 Main Landing Gear as the strut and wheel are fine.
Thanks for you help, I would like to get this bird back up in the air !
Bob
Bob
.png)
