Avanti Jet-installing the Admiral RX600SP Receiver
  • Flyingace123
    • Apr 2019
    • 5
    • Huntersville, NC
    I wasn't able to find anything on this. Can someone give me some ideas on installing this receiver (Admiral RX600SP Receiver) into the Avanti. I have everything all set and plugged in, just need to mount to center/flat area.
    Thanks!
    • 8835
    Since no one has responded all day, you may have it figured out by now. But ................ Take a look at the videos that Motion has on the product page. They may help you in this regard. They always advise to mount gyro type devices as close to the CG and center line of the plane as possible but this is not always possible and I’ve found that it is not really necessary. Just make sure you mount it on a flat surface that is as level as possible. Use a piece of double sided sticky cushion (1/8” thick is good). It can be off-center line and still work well. It can also be a reasonable distance away from the CG and still work. Just make sure that the orientation is as per the instructions (ie, the pins are facing the direction as indicated). Always test for correct gyro directional response on high gain, then turn down the gain for the first flight.
      Thanks!
      Welcome to Hobby Squawk, Flyingace123! As Xviper mentioned, watch our setup videos and you should be ready in no time. As far as placement in your Avanti, near the CG is ideal, but I tested the prototype Avanti with the RX600SP forward in the battery bay, on the raised foam "shelf" above the wooden battery floor.
