Landing gear on Stinger 64
  • gvc
    • Dec 2015
    Has anyone fitted their Stinger with the add-on gear and if so, how did it work?
  • Konrad
    Banned
    • 733
    • San Francisco
    RE: Landing gear on Stinger 64
    Which add on?
    Are you looking at what Sparks at Park Flier Plastics has done? If so it works very well.
    http://parkflyerplastics.com/cart/index.php?main_page=product_info&cPath=28_50&produ cts_id=683
    http://www.rcgroups.com/forums/showpost.php?p=26427237&postcount=33
    If you are looking at the one listed on the sales site it doesn't work well. It effects the CofG far too much.
    All the best,
    Konrad
    • gvc
      • Dec 2015
      Originally posted by Konrad
      Which add on?
      All the best,
      Konrad
      [hr]
      Thanks Konrad. I have too many "belly landers" and was looking for a small EDF with gear.
      • Konrad
        Banned
        • 733
        • San Francisco
        With the Park Flier Plastic mod I can take off from the runway (concrete). I can also perform touch and goes. About the only thing I can't do is slow taxi.
        I love the safety of not having to hand launch. With the 4 cell power set up a hand launch is a bit tricky, but very doable. And with the PFP mod there is no noticeable performance loss, ether from the wrong CofG or the drag of the LG wires and wheels.
        I think the MotionRC sales site has a plethora of small 64mm to 70mm jets that aren't belly landers. Some even have retracts at a very reasonable price.
        • ss0028
          • Oct 2015
          • 39
          The landing gear freewing offers is completely useless. All it does it slow the model down. If you are taking off from a solid surface you should be able to just skid with the skid plates for takeoff and landing. If you are in grass a hand launch would be well worth over gear.
          All the best
          • rc4ever
            • Jan 2015
            • 49
            • Little Rock, Arkansas
            All the best
            I Have to disagree, i got the gears here from Motion and they work fine. it took 200 feet to take off from neatly cut grass??? but on the other hand i had a 3500kv 4s 2200mah system with a 60 amp ESC and the only difference was top end with gear was 90 and without 110.
            Wow that was some time ago , i now only buy big jets that can handle a grass field, the smallest edf i have is a twin 64mm A-10, also with the same EDFs in it
