Freewing stinger 64 upgrade
  • jordan1387
    • 47
    • Iowa
    Has anyone upgraded the 4s stinger 64 to a 12 blade fan? Mine is stock and I love it and I was wondering if it would be any faster with the 12 blade fan or if it would just sound better. (I'm also aware I would need to upgrade the esc and maybe switch to the 3300kv motor.)
  • ss0028
    • Oct 2015
    • 39
    RE: Freewing stinger 64 upgrade
    I have and it adds around 15 more MPH to the speed. It is worth the upgrade. You can use the motor it came with and just get a 65 amp esc and the 12 blade edf. It will cost you around $40. You will also need a 4s battery with at least a 40c rating since the 65a esc has a 80amp burst.
    • jordan1387
      • 47
      • Iowa
      Ok thanks, I'm already using a 2200 45c battery. I heard someone say the stock motor won't last long with that upgrade? Just making sure
      • ss0028
        • Oct 2015
        • 39
        The stock motor for the 4s stinger is a 2836-3500kv. If you look under upgrades you will see a 12 blade complete assembly with the 2836-3500kv motor. All you need is the 12 blade edf unit for around $8 if you know how to move and mount a motor to a edf. I would get at least a 65amp esc as mine draws 60amps and you will need esc to motor bullet extenders if you get a ztw esc.
        • jordan1387
          • 47
          • Iowa
          I'll do that. I've never had to remove a fan or mount one to a motor but I'm sure it shouldn't be hard to figure out.
          • jordan1387
            • 47
            • Iowa
            Also would you recommend the 100mm extensions or the 200mm? And should I get the esc programming card or can I do it from my radio?
            • ss0028
              • Oct 2015
              • 39
              Just the 100m extension is perfect, you don't need the programming card you can do it all from your radio.
              • jordan1387
                • 47
                • Iowa
                Just ordered the upgrades. I'll let you know how it goes. Thanks again!
                • ss0028
                  • Oct 2015
                  • 39
                  Just so you know you only need the extensions for about 1 inch, without them the esc won't go all the way down, unless you modify the wiring.
                  Good luck with the upgrade I hope it all goes well!
                  • jordan1387
                    • 47
                    • Iowa
                    I installed everything today. Wasn't too hard to figure out how to remove and install the fan. I am having a little trouble with the motor stuttering and making a thumping sound when it starts up, but it only happens when it starts up and it seems to run smoothly other than that. I have some guys helping me fix it. It sounds awesome though! Can't wait to try it.
                    • ss0028
                      • Oct 2015
                      • 39
                      I sort of have the thump problem, can you let me know what you did to fix it.
                      Thanks
                      • jordan1387
                        • 47
                        • Iowa
                        Thanks
                        I won't have time to look at it until later this evening. Someone online said it could be a loose wire connection, screw too tight in the motor, or maybe change the startup speed to slow. I'll let you know if I fix it.
                        • jordan1387
                          • 47
                          • Iowa
                          Thanks
                          I still haven't figured out the thumping problem. I haven't flown it yet either because of the weather. I just remembered though, when I removed the motor from the stock 5 blade fan, I noticed the motor was screwed onto the housing with only 2 screws even though it could have 4. When I installed the 12 blade fan I screwed the motor onto the housing with 4 screws instead of 2, do you think that could be the problem?
                          • jordan1387
                            • 47
                            • Iowa
                            I finally got to fly it today and it went very well. It's definitely faster and it was worth the upgrade
                            • ss0028
                              • Oct 2015
                              • 39
                              Good to hear, good luck to all future flights
                              All the best
                              Sam
                              • paytonc11
                                How do you remove the ESC without cutting?
                                • DFJETFLYER
                                  • Oct 2017
                                  • 6
                                  Hello guys,
                                  i just purchased the upgrade EDF for my stinger 80amp esc. Will install tonight or tomorrow maiden Saturday. I'll post back on the flight.
                                  Mike
                                  • gazza
                                    • Apr 2018
                                    • 29
                                    yep i upgraded mine to a 11 blade powerfun edf unit, i was a bit staggered when i put it on the meter and it was pulling 70 amp, put a 80amp esc in it and it went well but on full throttle flight on a 2200mah 4s lipo i can only get a max 2 minute flight
                                    • daisydank
                                      • Apr 2020
                                      • 13
                                      hi
                                      thanks
