Yes they are in the same class and the Futura is the exact same kind of plane. A sport jet! They have their pros and cons but to say that the Futura isn't the same class of plane isn't really being honest. The wing loadings may be different but that doesn't change the class. I have flown both planes and the Futura V1 is faster than the Avanti V1 with 12 blade. Quite a bit faster actually! And when set up properly it doesn't behave much differently. Ground handling is actually better on paved surfaces because of the wide stance. Now the V2 Red Avanti with the 9 blade is a different beast speed wise! its quick! But I still think that the Futura is better on the top end. And with the FMS inrunner motor it is actually a superior set up in terms of flight times and cruising ability. the 80mm FMS fan is capable of 9-10 min flight times in the right hands. I have never seen an Avanti get more than about 5 even with mixed flying. Bottom line is that they are both really good choices. It just depends on which way you are leaning. Not about a brand name at all... just the flavor... I dig both!! But the inrunner makes me want the Futura...
FMS Futura V2
I am an RC addict and innovator that loves to share my knowledge with those that need help. Ask me anything via PM if you need help! Check out my Website here https://www.gooniac33.me/ -
If anything, I would be more concerned about changing the ESC as earlier FMS Predator ESC's were NOT made by Hobbywing like they are now. The failure rate was much too high previously. So, if it were me, I'd change the ESC to a 100A Hobbywing before thinking about the motor/fan, and then I'd check to see how balanced the Fan unit is from the factory. After that, I'd inspect the rest before the maiden flight to ensure all components are working as expected.Comment
They are using better components now... Plane is way better.................. 🤣If anything, I would be more concerned about changing the ESC as earlier FMS Predator ESC's were NOT made by Hobbywing like they are now. The failure rate was much too high previously. So, if it were me, I'd change the ESC to a 100A Hobbywing before thinking about the motor/fan, and then I'd check to see how balanced the Fan unit is from the factory. After that, I'd inspect the rest before the maiden flight to ensure all components are working as expected.Check me out on youtube at https://www.youtube.com/user/gooniac33
I am an RC addict and innovator that loves to share my knowledge with those that need help. Ask me anything via PM if you need help! Check out my Website here https://www.gooniac33.me/Comment
Well here's my plane.Comment
I like the "TOMAHAWK" graphic down the ventral spine! I have a thing for yellow and black.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
I'd go avanti hp. They are both faster than the V1, but I like that the nose on the avanti is replaceable as well as the lighting is a nice extra touch.Comment
