Freewing F-86 Sabre EDF setup.
  • lnelson15
    • Dec 2015
    • 3
    I am new to using elevators and ailerons as is on a new F-86 Sabre 64mm EDF I got from Motion RC. How are the elevators and ailerons suppose to work together. I have read a little and seen two or three different ways. Assume I am using a Spektrum 4 channel receiver with a y connector for the ailerons on a single channel. Should they be set to move in alternate directions in tandem with the elevators? I really have no clue so some guidance would be great. Thanks!!
  • ss0028
    • Oct 2015
    • 39
    RE: Freewing F-86 Sabre EDF setup.
    Welcome to the forum,
    Both elevators should always move the same way and the ailerons should move in opposite directions.
    What 4 channel remote do you have, some of them don't have full range which will cause you to loose signal to the plane and it will crash?
    • lnelson15
      • Dec 2015
      • 3
      I have a Spectrum AR400 4 Channel for this jet. I have fired up the receiver via the transmitter. I did the initialize on the ESC and the motor runs after I it plugged in with the right way. I have not connected the elevator and ailerons servo leads yet but will get to that later today. Thanks for the tip on the receiver..
      • ss0028
        • Oct 2015
        • 39
        I was talking about the transmitter not the receiver just so you know.
        Good luck!
        • lnelson15
          • Dec 2015
          • 3
          Good luck!
          Okay. No I am going to use a DX6i as it is convenient with the ability to have various fixed and rotary wing models.
