New E-Flite 80mm F-18
  • spyder1
    Pilot Officer RCAF
    • 13
    • I live in Calgary Alberta Canada
    Nice touch and go video,thank goodness some positive comments on this jet,I was thinking I made a poor choice.
    • Dustman
      • 81
      Evoman, is that a plastic one?
      • John Bergsmith
        • Mar 2019
        • 189
        • Concord, NC
        I put the first five flights on the Eflite F-18 80mm. The F-18 flies terrific, and has a wide speed envelope. Started with a C/G at 75mm and ended up moving the battery back well over 1” over the 5 flights. Takeoffs were no issue with some flap, and with full flaps landings were very smooth and easily controllable. Plenty of power, and the Hornet went through the aerobatic routine very smoothly. It does very nice four point rolls and looks good in the air. With an Admiral 6s 5000mah I had no problem getting a solid 4 minute flight. Eflite has a very nice handling jet that looks fantastic in the air with no bad characteristics I could find.
          John Bergsmith Thanks for your maiden report and CG confirmation! That's always helpful information. Nice picture, too.
          • John Bergsmith
            • Mar 2019
            • 189
            • Concord, NC
            I put 3 more flights on the Hornet yesterday. Great flying airplane, that looks great in the air. Landings are easy, and very scale looking as well. Very nice jet all around, Eflite did a solid job.
            Only thing I need to do is add a weapons officer in the back seat. Not sure why they left him out.
            • vduniec
              Hobby Squawk Pilot
              • 314
              Don’t sweat it too much. An empty seat in the back is going to be the norm soon enough.
              https://www.thedrive.com/the-war-zon...ith-pilot-only
              • John Bergsmith
                • Mar 2019
                • 189
                • Concord, NC
                I heard about that earlier this year. Don’t think that’s going to happen as fast as they think.
                • John Bergsmith
                  • Mar 2019
                  • 189
                  • Concord, NC
                  The Eflite F-4 didn’t come with a RIO which was sort of strange, but easily fixed.
                  • Scale Master
                    X USAF Pilot, Commercial IFR Jet Rated
                    • Apr 2019
                    • 86
                    Just finished a couple of weeks ago my second scale job on another one of my F-18D. She's nice and weathered in this one
                      Very nice weathering work, Scale Master ! Subtle, thoughtful, really well done!
                      • Scale Master
                        • Apr 2019
                        • 86
                        Thanks Alpha!!
                        • John Bergsmith
                          • Mar 2019
                          • 189
                          • Concord, NC
                          Looks fantastic!
                          • gooniac33
                            The Original Gooniac
                            • Jun 2016
                            • 1047
                            Man the bird above is gorgeous!! WOW!!
                            I have had mine for a while and love it! Just needed to make some changes to keep it in the air! A few people have has issues with the servos coming loose... so after replacing a bad servo I did a quick mod to help keep them in place...
                            • Crick3t
                              • Mar 2020
                              • 64
                              Has anyone upgraded this to a 90mm fan?
                              • gooniac33
                                • Jun 2016
                                • 1047
                                I just upgraded to the new FMS 2100kv fan. Drop in easy fit and perfectly balanced! I added a UBEC just to be safe but am using stock esc. The plane feels considerably better now!! Off the ground much faster, steeper climb and higher top speed!! Its simple and somewhat cheap considering too!
                                • Crick3t
                                  • Mar 2020
                                  • 64
                                  I just put the fms 2100kv fan setup in my eflite f18 and exactly as gooniac33 said way better now. More power all around. Better takeoff, vertical, power, everything!
                                  The 80$ doing the fms fan/motor swap is worth every penny. It's a totally different jet now!
                                  • PhantomNut
                                    • Sep 2018
                                    • 95
                                    • San Diego,CA
                                    Hi, Who did you order from?
                                      • 2708
                                      Scale Master is that a skunk in the dog bed? :astonished: BTW, outstanding looking livery. You sure earned your nickname with this one! :clap:
                                      • gooniac33
                                        • Jun 2016
                                        • 1047
                                        I was lucky enough to order direct from FMS before the shipping woes got in the way. I have more video from this past weekend and will share later
                                        • DForbes
                                          DForbes
                                          • Mar 2020
                                          • 31
                                          OK, read pretty much the whole thread and also watched Ryans setup vid. Hoping someone could validate the following setup.
                                          I am thinking setup as follows?
                                          - RT 6S 4400 70C
                                          - CG at 90mm?
                                          - 4mm up Elevator from neutral?
                                          - 50% flaps (per manual) 10% Elev Mix?
                                          - 100% flaps (per manual) 15% Elev Mix?
