Official Black Horse L-39 Albatros 90mm EDF Jet Discussion Thread
Alpha, this jet looks terrific! I have a Phoenix Models Hawk that is very similar in size and weight to the L39, and the construction method of laser cut ply and balsa sheeting appears to be similar too. Most of my jets with a turbine are either foam or composite and with my favourite engine, the tiny X45, this will power a jet from 3-6kgs, so this gives any potential small jet conversion a huge range of models to choose from. What really stood out for me about these ply/balsa jets is how strong and light they are! If I hadn't bought my Hawk, this would probably be on my Christmas list, plus it would be good if Motion made available a turbine conversion kit. These pics show my Hawk just to give a idea of how easy it is to convert a good quality 90mm EDF jet to turbine.Leave a comment:
Alpha, have you spoken with Black Horse regarding creation of new designs/models of wood aircraft?
Also, hopefully they (and Motion) would consider a "turbine conversion" version so to speak. It could come with turbine conversion in mind, and offer the kit with necessary components such as a fuel tank with fittings, pipe, possibly a UAT, etc., with or without it being installed from the factory.Leave a comment:
Yes the 105 might be a better choice since I haven't seen the structure . I have the HSD F-16 with the 105 and it's ok power , my buddy has the same plane with the 120 and it hauls the mail ! Larger inlets maybe needed for thisLeave a comment:
It's a big bird, I'd say the ducts can handle 105mm, but 120mm would likely require aux inlets and definitely new forward ducts. I'll measure next time I'm there.
OV10 is right, the physical surgery for 120mm is an entirely new chore.
If this were my daily driver, I would run it on a 90mm Wemo 10s setup for an economical package. If I wanted a showpiece, I'd run it on 90mm 12s JetFan or just convert to turbine. But that's just me.Leave a comment:
I'm thinking JP Hobby 105 or 120 Fan unit !!!!! Do we know what kind of retracts are going to be used ?Leave a comment:
On my list for 2020. At this rate, I might have to set up direct deposit at MRC.......Leave a comment:
alibakhti I have concerns about the MiG-29, having flown it, as does Black Horse. Perhaps we can forge an alternative way forward, because I do love the Fulcrum
Here are a few extra photos I took of Black Horse's L-39. Deceptively quick and some of you are right, it's a worthy candidate for turbine conversion. In fact subscribe to this thread for more news on that front.
Excellent to see this. Great job
. I would like to see some fiberglass or glass/balsa hybrid models offered by Motion as well.
Looks like a great plane to convert to turbine also. Maybe take off the covering, glass it lightly and paint too.Leave a comment:
I love it Alpha!!! Thank you
The next jet should be Black Horse MIG 29. Please!!Leave a comment:
The pdf file for the instruction manual on the product support tab link is damaged per Adobe.Leave a comment:
I agree, PaulZ! We've been working on bringing in bigger birds,, and Black Horse's popular 90mm 10s Albatros is a good place to start. It is noticeably larger than our Freewing 80mm 6s with similar although not identical flight characteristics.
For anyone wondering, this Black Horse L-39 is fully sheeted, too!Leave a comment:
I am so glad to see that bigger jets are coming to MRC! Excellent, thank you!Leave a comment:
Product Page: https://www.motionrc.com/collections...s-90mm-jet-arf
L-39 Albatros 90mm EDF Jet from Black Horse - Balsa Wood ARF - BHL3000
The Aero L-39 Albatros is a high-performance jet trainer developed in Czechoslovakia by Aero Vodochody. It was designed during the 1960s as a replacement for the Aero L-29 Delfín as a principal training aircraft. It was the first trainer aircraft to be equipped with a turbofan powerplant. The type was exported to a wide range of countries as a military trainer.
The model is scaled to approximately 1:7 and attention was paid to a true to original appearance and best flight characteristics. The model can be operated using an electric 90mm EDF setup. Comes covered in Oracover with a sporty and bold blue and white paint scheme. CNC cut balsa and plywood construction for strength and durability.
Visit the Official Black Horse L-39 Albatros 90mm EDF Jet Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A. FEATURES:- ARF model convenience for quick build
- CNC cut balsa and plywood construction
- Oracover covered in an attractive blue and white scheme
- Wing comes in 2 parts to facilitate transportation
- Control surfaces: Ailerons, elevator, rudder, flaps
- Scale suspended oleo struts (electric retracts not included)
- Hand painted pilots and cockpit detail
- Black Horse L-39 Albatros 90mm EDF Jet - ARF
- Scale CNC suspension oleo struts
- 8 Channel radio - select a minimum 8 channel radio from our Radio Collection
- 8 Channel receiver - select a minimum 8 channel receiver from our Receiver Collection
- Brushless Inrunner Motor - (recommendation coming soon)
- 10-12 Blade EDF Unit - (recommendation coming soon)
- 120 Amp Brushless ESC - we recommend ZTW Gecko 120A ESC OPTO High Voltage Brushless ESC
- 8-18 Amp UBEC - we recommend ZTW 18A BEC / UBEC
- 8x high torque servos - we recommend D-645MW (Note: these must be run at a minimum of 6V to generate enough torque.)
- For 8S to 12S setup - we recommend TWO Admiral Pro 4000mAh 5S 18.5V 60C LiPo Battery with EC5 Connector in series for 10S
- 2 to 1 EC5 series adapter - we recommend Admiral EC5 2 to 1 Series Adapter
- Electric retractable gear (73.5 x 44 x 28mm) - (recommendation coming soon)
Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). PRODUCT SPECIFICATIONS:
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 6+ HOURS
Model Scale 1:7.5 Scale Wingspan 1450mm / 57in Length 1860mm /73.2in Weight 4535g / 10.1lbs CG (Center of Gravity) Refer to the owner's manual Power System 10-12 Blade EDF with Inrunner Brushless Motor (required) Electronic Speed Control 120A Propeller / EDF 10-12 Blade EDF (required) Servos Electric - 8 x 45g standard (required) Landing Gear Electric retractable gear 73.5 x 44 x 28mm (required) Required Battery TWO 5 Cell 18.5V 4000 mAh LiPo Batteries with EC5 connector in series (required for 10S setup) Required Radio 8 Channel (required) Ailerons Yes Elevator Yes Rudder Yes Flaps Yes Lights N/A Hinge Type Nylon Heavy Duty pin hinges Material Balsa and plywood Skill Level Intermediate Build Time 6+ Hours Recommended Environment Outdoors
