LX B-2 Spirit Complete Overhaul/Redesign
Thanks Xviper! Just listed this project for sale here if anyone is interested: https://www.rcgroups.com/forums/show...design-Project -
You made a tremendous effort at a time when it was so needed. You should be applauded for it. I almost went your route myself, but then, it involved Banana Hobby, so it never happened.Leave a comment:
Sometimes a project sits on the shelf too long… Looks like Freewing beat me to the finish line. Just preordered their B-2. If anyone is interested in the guts of this project, let me know.Leave a comment:
I remember my LX F-117 years ago...Bone stock...Was a slug in the air but I recall it flew decent. Tons of drag.Leave a comment:
That’s awesome I’ve always thought that would actually fly really good. I would guess it feels like a race wing with really bad drag.Leave a comment:
I actually tackled the F-117 already, and it’s a surprisingly good flyer when setup correctly! It’s on the bench right now due to a dead aileron servo, but it is very well behaved in the air. Flies similarly to a pop wing with a giant speed brake on it :). I switched out the power system for an FMS 12 blade 4S fan, added spars, electric retracts, shock struts, and sequenced gear doors.4 PhotosLeave a comment:
This project is absolutely amazing to me. Maybe you should tackle the LX SR-71 in the future or the F117😱 always wanted a flying cheese wedgeLeave a comment:
Thanks for tip Elbee, I’ll give that a try!F106DeltaDart, 90% IPA will dissolve most acrylic paint. I used that to remove all the paint from my F-4 canopy and re-masked the for a more accurate canopy frame and window shapes. Could you do that for this? Best, LB
Thanks Tom!
Aros, I can only hope it turns out as well as the B-25 did! This one definitely has a few extra layers of complication though!
One of the next things I need to tackle is reinforcement for the center section. With the battery bay, bomb bay, gear bays, and ducting, space to run a spar is near non-existant. What I will most likely end up doing is getting some 1.5-2mm carbon sheets water jet cut to reach around these. Ideally, these frame could also tie into the main gear mounts.
Michael, this is going to be a fantastic update on the old LX model. Watching closely.Leave a comment:
Not much progress today, but I’ve been messing with tape to see what it will take to get the windshield looking a bit more scale. There is definitely an improvement by altering the shape of the windows, but the angle of side braces really bothers me. It gives the side windows quite a different look than the real thing. I’m also not a fan of the thick raised canopy frames. The real frames are perfectly flush to avoid radar returns. For now, I’ll probably just modify the stock one a bit, but if I can get it flying well, I might end up making a new windshield from the start.
Real B-2:
Stock:
Excess Window blocked by tape:
This is a great project, and it is looking spectacular. It is already SO much better than LX designed it.Leave a comment:
