Question about upgrading to "bigger" EDF
    tab28682 Is right on the money!
    • tab28682
      RC addict
      • 334
      • Fort Worth, TX
      Thanks, Alpha. Higher praise I rarely get!
      • Wrthog
        • Feb 2020
        • 55
        I’m a no one here but I upgraded my mig 15 from 70- 80 mm and it was a huge difference! Stock 70mm on 4s was 64 mph straight and level had to fly 3/4 most of the time to putt around. Went with a freewing 80mm and hit 115 today! 2 min extra flight time as well same 3200 pack. Also added same set up to my e flite viper that sumbitch rips now! Clicked 136 MPs on a 3300 6s.
        I agree with some ducting issues, may cause or hinder performance with some models but others not do much. Another thing to think about is esc set up for outrunner be inrunner and timing, which can make it break a system and how it performs. Just my thoughts
        • Rctoddler
          • Jun 2022
          • 2
          Going from a 80mm to 90mm or 80mm from a 70mm is a big jump. But took a twin 64mm SU34 from a 4s battery to twin 70mm with twin 80anm escape to a 6s 4000 mah 100c...and the plane is a missile
          • Rctoddler
            • Jun 2022
            • 2
            Also the old 64mm were out runner motors with a 5 bladed edf. Horrible sound and sucked too much amps. The new 70mm are inrunners...with a 12 bladed fan...and OMG what an amazing difference. 420 flight tines and super scale sound....with a 1 ok 1 power to weight ratio. My new favorite jet with thrust vectoring
            • Woohoo\o/
              • Feb 2020
              • 186
              • Cape coral Florida
              Sorry to revive this thread but thought I drop my curiosity regarding this topic. I own an HSD viper 75mm kit. I ordered a freewing 80mm 12b 6s power system from motion. Since this is 5mm difference, do you think it’s plausible to move forward with this mod? The airframe has vents on the top deck. I would imagine it would work out just fine. I will have to hog out some foam for perfect fitment. If anyone would chime in. All opinions will be taken into great consideration.
                • 5393
                Yep, should be fine
