Who would be interested in a FreeWing F-14 V2/refresh?
  • evensen007
    • Jul 2020
    • 101
    • Asheville, NC
    I'm 'new' to the hobby after being out for almost 20 years. I've come back pretty furiously after seeing the impressive development and takeover of foam electrics. I've got the 80mm A10, e-flite f-4, and recently pre-ordered the new mig-29 after seeing the impressive unveiling. I would have bought the F-14 (my favorite jet fighter ever) first, but the fit and finish on the new mig was insane. Alpha and team hit an absolute grand slam. I am 100% going to purchase the f-14 next, but wondered how much interest there is in a potential refresh of the f-14 to the newest standard that alpha has set with the latest mig. I'm not just talking about the retracts, spacious cabin, powerplant etc. I'm talking the stunning fit and finish, killer paint/graphics, size and scale. I hope others would be into an update for this icon, but also understand if it really wouldn't be worth Alpha's valuable time since he cranks out a new stunner every year. I wonder where the f-14 ranks on motion's jet sales and hope it's high so they see the value and potential of doing it.
  • flyAA
    lineholder
    • 116
    • Va Beach
    I’d love a new f-14 as well. However, if the current f-14 sells well i doubt they’d do a refresh. Alpha has mentioned the almost half a million it costs to get a new airplane to market.
    i hope I’m wrong and they come out with a huge new twin 90 tomcat but i doubt it.
      Here's my suggestion on the F-14. Get the ARF+ ($439), then buy two of the T-33 80mm inrunner power systems ($76 each), and match them with the A-10 ESC set ($119). This is basically the same power setup as the upcoming Mig-29 and should push the F-14 very well. I'm currently building my second one and repainting into the old VF-1 Wolfpack scheme from the 70's, and will be putting this power system in it instead.
      As far as the fitment of the foam, the only bad part is the cover over the wing sweep mechanism. But we've found that if you trim the foam on the underside of the cover in certain places, it fits better.
      Since this is already a twin 80mm bird, don't expect a "V2" from Freewing. The only thing I could see them doing is offering a "high performance" version with this new inrunner system.
        • 8835
        I did just this. Bought the ARF from Motion and the complete power system (IR’s, ESCs, BEC) from RC Castle. Thanks for the tip about trimming the underside of the swing wing cover. I’ll also clear coat all the foam surfaces. Viewing the RC Informer build video and taking notes.
          • 5426
          Here's how mine ended up after a lot of work trimming and heat massaging. Also a lot of battery area clean up.
          . Click image for larger version
ID:	269138Click image for larger version
ID:	269139Click image for larger version
ID:	269143Click image for larger version
ID:	269140Click image for larger version
ID:	269141Click image for larger version
ID:	269142Click image for larger version
          • evensen007
            • Jul 2020
            • 101
            • Asheville, NC
            I will wait to hear your report out on how that works! If it's good, I will probably follow your lead. I guess I don't mind reinforcing the landing gear, carving out the battery cavern, and trimming the foam under the sweep wing to get it to function properly; it's just that I'd rather not have to do all that. My guess is that if Alpha had another crack at this in 2020 he would change some of these things to match the quality being achieved on the new jets. Imagine this tomcat at the size and quality of the new Mig. Either way, I am going to buy it but now I'm going to wait for Pat to report back on the t-33 power system in this thing!
            • flyAA
              lineholder
              • 116
              • Va Beach
              There’s a few videos out there on Facebook of the tomcat flying with that power sysytem. Check EDF clubhouse or Motion RC customer community.
              • Rcfiddy1
                Professional Crash Test Dummy
                • Aug 2015
                • 186
                • Manalapan, NJ
                I’ve flown mine with the a10 power system, upgraded main gear support and battery tray mod. I don’t see a need for a v2. It’s a heavy bird and most of the weight is in the swing wing mechanics. These wings are built to support this bird by just the pivot bolt so I’m sure the wings are heavier than normal carbon spar types. The only upgrade I would’ve like to see would be those rotating gear. Love my dirty cat.
                  I'm always up for bigger, better, faster, more.
                  I think part of the trend of advanced tech would be lighter weight materials without compromising integrity/strength. If we can increase strength and durability while decreasing weight, wow. Maybe a pipe dream but that is the goal. Imagine flying a giant scale F-14 with full amenities yet with a relatively low wing load? Incredible.
                  • evensen007
                    • Jul 2020
                    • 101
                    • Asheville, NC
                    GREAT weathering! I love it!
                    • evensen007
                      • Jul 2020
                      • 101
                      • Asheville, NC
                      This guy gets it! :) YES, please!
                      • Rcfiddy1
                        • Aug 2015
                        • 186
                        • Manalapan, NJ
                        Lighter than foam would mean composite materials. Carbon wing box, hollow fuse.
                          JMB Jets is using something fairly new called Airex on their composite turbine jets. It's a foam-type material with a hard shell like fiberglass. I have their MB-339 and it weighs about 18 lbs wet with an 80 size turbine. The Freewing A-10 is 13 lbs AUW, so it's not far off that. Of course, Freewing would need to totally redo how they make models. They're doing balsa kits now, maybe one day they'll move up to selling turbine kits as well.
                          • Rcfiddy1
                            • Aug 2015
                            • 186
                            • Manalapan, NJ
                            Actually freewing is not doing balsa models as far as I know. Motion carries other brands that do balsa kits but freewing is all foamie.
                              Yeah, I meant Motion is carrying balsa kits now. Maybe one day they'll start stocking some turbine stuff.
                              • Rcfiddy1
                                • Aug 2015
                                • 186
                                • Manalapan, NJ
                                I’m in the fence right now with turbine. I’d love one but I don’t have many fields that allow them. The one field by me that does allow it does not have a great runway. At best it’s bumpy grass/ hard packed sand. Not very friendly especially for a turbine blade. But these small turbines look promising to adapt to a nice foamie in my opinion. Adding more power than a edf would make planes like the 90mm f16 wake up.
