Hi guys,
My club has a well groomed 800ft grass strip. I have had no problems flying my Avanti at the field but last weekend I went to maiden my F-86 and could not get enough speed to rotate on takeoff. I discovered that it sucked up a lot of grass clippings clippings loading the fan and stator. I am going to add some screen over the cheater hole on the bottom of the fuse to hopefully eliminate the problem. I am concerned I will have the same issue with my F-4 and F-18. Has anyone added screen to the cheater hole and did you notice any issues with performance?
Thanks!!
Anthony
Thanks!!
Anthony
The Avanti also is not bothered much by wet grass and it's always a good time to work with my 3D planes. I once tried my F-16 at 8:30 in the morning (which has it's primary air intake on the underside of the frame just in front of the EDF) and of course it never got off and looked like the Miss Budweiser Hydroplane cruising down the runway. It was actually quite hilarious to watch.
