The RCINFORMER FREEWING F-14 Thread for any and all Q&A on the Freewing F-14 TOMCAT
    Originally posted by Elbee
    xviper what is the weight of your aftermarket CNC alum parts? Best, LB
    I didn't get them. After analyzing what the upgrade plates did for this plane, I decided their primary benefit was to reinforce the main gear area and that seam. When you put pressure on the retract as when landing, the seam opens up. So, I elected to embed the CF square rods near the main retracts and pushed more glue into and along the whole seam. To the best of my recollection, those rods were about 6mm square and about 7" to 8" long - one on each side. Contrary to what others may have thought, I decided the stock wing plate and accompanying assembly was up to the task.
  • dk91105
    Pull the plates? The stock plane has none.
    I am referring to the plates that these replace. I will deep dive into this (as it's the only way I know how) when I get my hands on the parts. If I saw correctly the stock plates are close to 3mm and I'll l tell you 3mm CF is mighty rigid.
    Originally posted by dk91105
    I'm going to find out soon. My TC is on the road and the first thing I'm doing is pulling the plates and most of the electronics.
    DK, could you weigh those alum parts and post those? Very thankful, LB
    Could he be talking about the bottom "plate" in that whole assembly that holds the wing swivel/mount and held together by those cross bars? As shown at 28:08 in Rich's assembly video? The upgrade plates are just those plates but with the extension "wings" for the retract reinforcement.
    Isn't there a big difference in overall size and coverage of the custom plates? The replacement plates extend further aft to make for a reinforcement and possible attachment (if so chosen) for the main retracts. I think the stock wing plates are strong enough and it's the area above the main retracts that was weak due to a seam that runs fore/aft in that area - this seam wasn't even glued very well. After having a couple of very rough landings, which resulted in a cartwheel, I'm of the feeling that only the main gear area needs strengthening. The wing plates are fine. The embedded CF square rods over the main retract housing and that seam, appears to have done quite an adequate job.
    I never got the custom wing plates so can't say about a weight comparison, but I think because the upgrade ones have so much more material (aluminum), it's gotten weight more. CF would be lighter than AL and should exhibit similar, if not better strength. However, like AL, CF will begin to flex at a certain thickness. At what thickness, I have no idea. Just for comparison (although not scientific) I replaced my aluminum hood on my old sports car with a CF one. Both had the same sort of bending strength but when you push on the CF, it bounces back. When you push on the aluminum one, it bent (dented) and stayed that way.
  • dk91105
    Evan D dk91105 my thought about replacing the OEM aluminum plates with CF plate is 2-fold, lighter weight and thinner material. 3mm alum versus say 2mm CF. I cannot find comparisons of weight to strength gain/loss, if that makes sense. Wondering if it is worth the effort. An overall savings of even a half a pound is worth it to me. There's got to be a way to this bird on a diet. I would think. Best, LB
    The aluminium plates are fairly heavy. When I bought my second TC it came with the kit uninstalled. I chose to sell it instead of installing it. I fly off pavement and had no issues with my first TC.
  • dk91105
    Thanks, I have yet to open the box, so I have spoken without knowing. Does anyone think there could still be a weight savings with CF. Best, LB
    Honestly not sure but it definitely wouldn't add any weight if made with the same 3mm thickness and not to mention look a hell of a lot better.
    I was under the impression the stock plates and aftermarket versions were aluminum?
  • SanExup
    They are aluminum.
  • dk91105
    Et al, I think a CF replacement for the steel plates in the Tomcat is a great mod idea. Any stats on CF thickness to weight/strength versus steel would be appreciated. I like the idea of exchanging weight for performance. Best, LB
    Where are you located? Maybe we could face time?
  • mauricesize12
    Originally posted by mauricesize12
    thank you. I appreciate it. I forgot to mention as crazy as this may sound but I’m a gamer and I play a lot of GTA. I’m almost possible that the simulation is very similar. I’m excellent on that game as well as flight simulator. . Now I am trying to set up the wiring on the board but there are no videos or anything that assist. Do you know anyone that could help me with setup over the phone.
  • mauricesize12
    This is one of the more complicated planes to set up AND tricky to fly, even if you never sweep the wings in during flight. When it first came out many years ago, there was a warning on the product page at MotionRC. It stated that this plane was NOT for new pilots and was more for expert types of RC pilots. They have since removed that warning for whatever reason, most likely because enough people in the marketplace has this plane and are there to help and advice those who buy this product and to be there to pass on the warnings and cautions. A lot of set up and procedural things have been discovered along the way that are not covered in the manual or in many of the videos so far provided. This is one of those times when "buyer beware" is applicable, not so much in the sense that it's anything to do with product quality or questionable seller behavior, but more because there are so many "blind corners" in the operational aspects of the plane. Perhaps if you are really, really good with video games and flight simulators, you might be alright but history has shown this is highly unlikely.
  • dk91105
    Originally posted by SanExup
    dk91105
    Those look great. Are you purchasing the carbon fiber plates and just router cutting them? Or vacuum bagging parts and routing them? Where do you get the plates from? I assume you have a good vacuum system as I've read that CF dust is carcinogenic. I have a cnc machine as well that I use for work but have wanted to use it for hobbying. I just haven't delved into it but can see using it for routering CF and creating stiffness and reinforcement.
    I am going to try and not derail this any further but I buy the CF plates from amazon. If you need any further info message me.
  • SanExup
    dk91105
