The RCINFORMER FREEWING F-14 Thread for any and all Q&A on the Freewing F-14 TOMCAT
    Originally posted by Couchbr
    Just wondering if the reinforcement kits are still avalible and how do I go about getting one. Thanks for the help.
    Dustin Holloman aka Raven Rock along with Rich Baker designed these aluminum plates and plywood battery tray modification.
    Contact Dustin Hollowman for the Wing Platter Kit: Ravenrocktoc@gmail.com for more information.
    Below is a link to most of Rich Baker RCINFORMER videos for the 80mm Tomcat mods he made.
    Best, LB
    Hey Folks, I am trying to Get out all the information on the Freewing F-14 that I have included in my videos and circulated around, for folks that would like to ask questions and get help on this epic model. I have put in a lot of effort on this model and wanted to share everything about it and some of the improvements I have
  • Couchbr
    My understanding is you would need to totally reprogram the E20. Not something you can change in the transmitter.
  • Nickel
    I put the E20 in my 80mm F-14 and the flaps work when wings swept.. not good. 2. ailerons work with elevator (tailerons) but not with ailerons (tailerons) any ideas.. I have tried all variations and reversing.. what else.. Thanks, Nickel
    Hey All,
    Does anyone own/know of a derelict or crashed Tomcat they'd be willing to part with for a reasonable amount?
    I ask as I'd like to do some reverse engineering and use it as a workhorse for measurements, etc for my ARF+ project.
    I'd pay shipping, of course.
    Please, keep me in mind if you hear of one that's seen better days and is ready for the bin.
    Best, LB
    Originally posted by freakbrother
    So do I. The 80 is easy to land despite being so heavy. The 64 has a tendency to drop a wing if you get too slow.
    Did you upgrade the power in yours? I put FMS 3665 2000kV fans in mine and they made a whole lot of difference.
    I did but I can't remember exactly which one since it was years ago. It's Freewing upgrade, still not as powerful as the current generation of fans.
    Just came back from the morning flying. The old F-14 flew flawlessly. It's amazing how slow it will go with the wings swept back. Next time, I may try to land it with the wings swept just to see (assuming I have the nerve). Last landing was perfect except for hitting a small gopher dirt mound. Sheared off one strut. I think I have another spare or a friend can machine a new pin for me.
    For some strange reason, I find the 80mm easier to fly than my 64mm one.
    Originally posted by Elbee
    xviper
    Looking forward to your debrief.
    Best, LB
    It's been a long time since I flew it, I hope it's not a TSB (or NTSB in your area) investigation. :face_with_raised_ey
    xviper
    Best, LB
    This thread has been dormant for nearly 2 years and RCInformer hasn't been heard from for about a year (his last YouTube video). Hope he's OK.
    Nevertheless, this has reminded to to give my old F-14 some love. Taking it out tomorrow for a blast around the field.
  • inchi41
    Originally posted by dk91105
    Done, thanks. We will see if he responds. From what I am finding on the internet and youtube videos on the subject nobody has really discussed the plates much in the past 2 years. Worse case I will pull the stocks, reverse engineer them, and based on photos and videos add the extra material on. I am wanting to cnc cut my own from carbon fiber sheet, either 4 or 5mm thickness. 3mm would also probably work as the stuff is ridiculously rigid.
    I just asked the same question about carbon fiber did you use it ?? If so what thickness and has it worked out ok. Cheers
  • Doutrnz
    They are a retract. No end point adjustments. You could redrill the servo arm to have less throw but I just ground clearance into the plastic on the wing root.
    They will apply full force at the end of travel and then over current and shut off. But they will over current and it could be enough to pull the link off the wing root. On mine a ground into the plastic where it bottomed onto the upright tubes enough so it wouldn’t bind either direction.
    Thanks for that tip. I'll do that instead. It's a simple yet effective solution.
  • Doutrnz
    Does anyone know the length of the swept wing pushrods are supposed to be? When I extend the wings, everything is cleared and the flaps can work. When swept, they sound BAD. They sound like they are crushing something in a hydraulic press. So, naturally, since they push out to make the wings retract, I shorted them a little so they wouldn't have to extend as much.
    Well, that made it worse. The more I seem to shorten the length, the more it sounds worse. This now made the extended position too short in the extended position. The flap cannot come down.
    Can you set the endpoints for those landing servos (swept wing servos)?
    What should the length be set to from center point of the ball joint to center point of ball joint? This I need to know because now I can't get the length set back to default.
    Do the servos sense when its getting tight and shut off or will they keep trying to extend and burn up?
  • Doutrnz
    Originally posted by Flyingace123
    Is there a spot here that explains the programming for disconnecting flaps when in swept wing position-I have an 8 channel spektrum with DX9
    I reached out to RCGeek about the setup as well. I haven't heard back from him yet.
    commented on 's reply
    Thanks much.
ID:	371365 I used jbweld plastic weld epoxy for mind, and I just used the same thickness as the aluminum plates, if I remember correctly 3mm. But I would still cut away the foam above the gear mount and reinforce it directly to the plate with a small piece sandwiched between the mount and plate that will help a great bit keeping the flex out of the foam as i also did mine differently and left the factory cf cross rod system in place for support as well. These been holding strong, so far so good.
    rifleman_btx, What thickness is your CF plate? Also, likey the epoxy rather than kit glue or E6000. Any other suggestions on where to look to cut some ounces? Best, LB
    The CF will be absolutely fine. Your struts will bend before the body gives up, I didn't replace the entire plates, what I did was add an extension off the stock plates then put a second piece in under both plates to fuse them together with 30 minute epoxy. The second carbon plate also was glued down to the retract mount and drilled through so the mount would also have its original screws in place. Crossed fingers 🤞 so far it's been working great.
    Smart and clever. You have a point and there's no doubt what is there is fine, I am just seeking a way to reduce overall weight and that alum (which I thought was steel) plate seems a good starting point. Like others, I'd like the template of the upgrade plates to save some time switching out to a CF plate. We'll see. Best, LB
